Thank you, i did find the mtk_aes module and compiled it into lede. It appears to work OK for SSL timings (very very well)… but when openvpn is used with the module the packets are not crypted corrrectly. i checked it was using cryptodev but it did not do too much
what is your recommendation for a reasonable price GL.inet product which supports hardware AES offload for openvpn?
