I am interested in using an internally mounted micro SD memory card with the MT300N-V2 router.
I see the board has a row of 9 connector pads that looks to be the same as the connector for the micro SD card daughter board on the MT300A router (now discontinued).
Some questions please:
- Is this connector on the MT300N-V2 intended for use with the micro SD daughter board?
- If so, is the daughter board available?
- Is there a description of the pinout for this connector available?
Thanks in advance for any information.
