Is it possible to get the new MT300N-v2 router with the option of external aerials? Or, is it possible to retrofit external aerials to an MT300N-v2 that was originally supplied with internal aerials?
Thanks
Thanks
We are not producing external antenna version of MT300N-V2
If you have hardware skills you can modify the hardware. You need to detach the internal PCB antenna.
HI alzhao,
External antenna jack(s) and the antennas would be a nice option or enhancement.
I would like to attempt to add an external antenna, but I must admit I’m not sure what adjustments I need to make to detach the internal antenna. Is it just a case of cutting the connection of the smd connector to the internal antenna or do I have to cut or desolder a component (like an inductor) somewhere?
Thanks
