I had a similar problem: wifi constantly drops and reconnects. From Ubuntu the problem wasn’t so annoying because it silently reconnected but on Windows 10 it was almost not possible even to do something on admin panel. In the same time the router was under load from TV. It was slightly heat but not hot.
I updated firmware to the last 3.X.X but the problem still occurred.
I changed Wifi transmittion power to 16 but this not helped.
I changed adapter to a bigger one from iPad that gives 2A and this not helped.
In Luci I opened System Log but there was nothing special except of hundreds of the message that my computer stokito-serv recconnects:
Sat Oct 3 22:42:06 2020 daemon.info dnsmasq-dhcp[2367]: DHCPREQUEST(br-lan) 192.168.8.147 2c:fd:a1:60:c9:7c
Sat Oct 3 22:42:06 2020 daemon.info dnsmasq-dhcp[2367]: DHCPACK(br-lan) 192.168.8.147 2c:fd:a1:60:c9:7c stokito-serv
Then I installed OpenWrt 19.07.4 and now in Luci I can see Wireless menu (i.e. opensource driver) and there I removed SSIDs and created a new one from scratch.
Now it works fine but on the first connection I again had one drop of wifi and in the logs found some error call stack:
Sun Oct 4 09:18:09 2020 daemon.info dnsmasq-dhcp[1469]: DHCPOFFER(br-lan) 192.168.8.167 e0:1f:88:94:22:56
Sun Oct 4 09:18:09 2020 daemon.info dnsmasq-dhcp[1469]: DHCPREQUEST(br-lan) 192.168.8.167 e0:1f:88:94:22:56
Sun Oct 4 09:18:09 2020 daemon.info dnsmasq-dhcp[1469]: DHCPACK(br-lan) 192.168.8.167 e0:1f:88:94:22:56 Redmi8-Redmi
Sun Oct 4 09:18:09 2020 daemon.info hostapd: wlan0: STA c0:a5:3e:0d:b9:fc IEEE 802.11: authenticated
Sun Oct 4 09:18:09 2020 daemon.info hostapd: wlan0: STA c0:a5:3e:0d:b9:fc IEEE 802.11: associated (aid 5)
Sun Oct 4 09:18:09 2020 daemon.notice hostapd: wlan0: AP-STA-CONNECTED c0:a5:3e:0d:b9:fc
Sun Oct 4 09:18:09 2020 daemon.info hostapd: wlan0: STA c0:a5:3e:0d:b9:fc WPA: pairwise key handshake completed (RSN)
Sun Oct 4 09:18:09 2020 daemon.info dnsmasq-dhcp[1469]: DHCPREQUEST(br-lan) 192.168.8.241 c0:a5:3e:0d:b9:fc
Sun Oct 4 09:18:09 2020 daemon.info dnsmasq-dhcp[1469]: DHCPACK(br-lan) 192.168.8.241 c0:a5:3e:0d:b9:fc iPhone-Ksenia
Sun Oct 4 09:18:54 2020 daemon.info hostapd: wlan0: STA 8c:70:5a:46:aa:4c IEEE 802.11: authenticated
Sun Oct 4 09:18:54 2020 daemon.info hostapd: wlan0: STA 8c:70:5a:46:aa:4c IEEE 802.11: associated (aid 6)
Sun Oct 4 09:18:54 2020 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 8c:70:5a:46:aa:4c
Sun Oct 4 09:18:54 2020 daemon.info hostapd: wlan0: STA 8c:70:5a:46:aa:4c WPA: pairwise key handshake completed (RSN)
Sun Oct 4 09:18:54 2020 daemon.info dnsmasq-dhcp[1469]: DHCPREQUEST(br-lan) 192.168.8.146 8c:70:5a:46:aa:4c
Sun Oct 4 09:18:54 2020 daemon.info dnsmasq-dhcp[1469]: DHCPACK(br-lan) 192.168.8.146 8c:70:5a:46:aa:4c stokito-note
Sun Oct 4 09:18:56 2020 daemon.info dnsmasq[1469]: read /etc/hosts - 4 addresses
Sun Oct 4 09:18:56 2020 daemon.info dnsmasq[1469]: read /tmp/hosts/odhcpd - 2 addresses
Sun Oct 4 09:18:56 2020 daemon.info dnsmasq[1469]: read /tmp/hosts/dhcp.cfg01411c - 6 addresses
Sun Oct 4 09:18:56 2020 daemon.info dnsmasq-dhcp[1469]: read /etc/ethers - 0 addresses
Sun Oct 4 09:19:03 2020 daemon.err uhttpd[977]: luci: accepted login on / for root from 192.168.8.147
Sun Oct 4 09:21:04 2020 daemon.info hostapd: wlan0: STA c0:d3:c0:bc:c9:2f IEEE 802.11: authenticated
Sun Oct 4 09:21:04 2020 daemon.info hostapd: wlan0: STA c0:d3:c0:bc:c9:2f IEEE 802.11: associated (aid 7)
Sun Oct 4 09:21:05 2020 daemon.notice hostapd: wlan0: AP-STA-CONNECTED c0:d3:c0:bc:c9:2f
Sun Oct 4 09:21:05 2020 daemon.info hostapd: wlan0: STA c0:d3:c0:bc:c9:2f WPA: pairwise key handshake completed (RSN)
Sun Oct 4 09:21:06 2020 daemon.info dnsmasq-dhcp[1469]: DHCPREQUEST(br-lan) 192.168.8.103 c0:d3:c0:bc:c9:2f
Sun Oct 4 09:21:06 2020 daemon.info dnsmasq-dhcp[1469]: DHCPACK(br-lan) 192.168.8.103 c0:d3:c0:bc:c9:2f android-7d3e967dbd380869
Sun Oct 4 09:21:16 2020 daemon.info dnsmasq-dhcp[1469]: DHCPREQUEST(br-lan) 192.168.8.103 c0:d3:c0:bc:c9:2f
Sun Oct 4 09:21:16 2020 daemon.info dnsmasq-dhcp[1469]: DHCPACK(br-lan) 192.168.8.103 c0:d3:c0:bc:c9:2f android-7d3e967dbd380869
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.057187] ------------[ cut here ]------------
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.061900] WARNING: CPU: 0 PID: 0 at net/sched/sch_generic.c:320 0x802c5530
Sun Oct 4 09:24:29 2020 kern.info kernel: [ 427.069075] NETDEV WATCHDOG: eth0 (mtk_soc_eth): transmit queue 0 timed out
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.076134] Modules linked in: pppoe ppp_async pppox ppp_generic nf_conntrack_ipv6 mt7603e mt76 mac80211 iptable_nat ipt_REJECT ipt_MASQUERADE cfg80211 xt_time xt_tcpudp xt_state xt_nat xt_multiport xt_mark xt_mac xt_limit xt_conntrack xt_comment xt_TCPMSS xt_REDIRECT xt_LOG xt_FLOWOFFLOAD xt_CT slhc nf_reject_ipv4 nf_nat_redirect nf_nat_masquerade_ipv4 nf_conntrack_ipv4 nf_nat_ipv4 nf_nat nf_log_ipv4 nf_flow_table_hw nf_flow_table nf_defrag_ipv6 nf_defrag_ipv4 nf_conntrack_rtcache nf_conntrack iptable_mangle iptable_filter ip_tables crc_ccitt compat nf_log_ipv6 nf_log_common ip6table_mangle ip6table_filter ip6_tables ip6t_REJECT x_tables nf_reject_ipv6 leds_gpio ohci_platform ohci_hcd ehci_platform ehci_hcd gpio_button_hotplug usbcore nls_base usb_common
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.144190] CPU: 0 PID: 0 Comm: swapper Not tainted 4.14.195 #0
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.150204] Stack : 8046fee0 80054358 80480000 8042ed5c 00000000 00000000 00000000 00000000
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.158713] 00000000 00000000 00000000 00000000 00000000 00000001 87c07de0 ac07f5da
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.167213] 87c07e78 00000000 00000000 00003738 00000038 803ce8b8 00000008 00000000
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.175700] 00000000 80460000 0002333e 00000000 87c07dc0 00000000 00000000 80428c10
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.184197] 802c5530 00000140 8046ff34 8046fef4 00000002 8021cfc0 00000000 805b0000
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.192702] ...
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.195185] Call Trace:
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.195198] [<80054358>] 0x80054358
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.201273] [<803ce8b8>] 0x803ce8b8
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.204818] [<802c5530>] 0x802c5530
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.208375] [<8021cfc0>] 0x8021cfc0
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.211917] [<8000aa50>] 0x8000aa50
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.215452] [<8000aa58>] 0x8000aa58
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.219011] [<80026480>] 0x80026480
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.222552] [<802c5530>] 0x802c5530
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.226096] [<80026508>] 0x80026508
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.229650] [<8026dcf0>] 0x8026dcf0
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.233202] [<802c5530>] 0x802c5530
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.236742] [<802c53cc>] 0x802c53cc
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.240297] [<8005ffcc>] 0x8005ffcc
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.243834] [<8000e0a4>] 0x8000e0a4
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.247392] [<800601a0>] 0x800601a0
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.250933] [<8029f018>] 0x8029f018
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.254489] [<87fe0000>] 0x87fe0000 [usbcore@87fe0000+0x1f5b0]
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.260424] [<803d4368>] 0x803d4368
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.263961] [<8005a554>] 0x8005a554
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.267515] [<80055ab0>] 0x80055ab0
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.271066] [<87fe0000>] 0x87fe0000 [usbcore@87fe0000+0x1f5b0]
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.276992] [<87fe0000>] 0x87fe0000 [usbcore@87fe0000+0x1f5b0]
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.282923] [<80005e90>] 0x80005e90
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.286457]
Sun Oct 4 09:24:29 2020 kern.warn kernel: [ 427.287978] ---[ end trace 312f46205de38a69 ]---
Sun Oct 4 09:24:29 2020 kern.err kernel: [ 427.292671] mtk_soc_eth 10100000.ethernet eth0: transmit timed out
Sun Oct 4 09:24:29 2020 kern.info kernel: [ 427.298961] mtk_soc_eth 10100000.ethernet eth0: dma_cfg:00000055
Sun Oct 4 09:24:29 2020 kern.info kernel: [ 427.305070] mtk_soc_eth 10100000.ethernet eth0: tx_ring=0, base=077c8000, max=1024, ctx=210, dtx=210, fdx=116, next=210
Sun Oct 4 09:24:29 2020 kern.info kernel: [ 427.316024] mtk_soc_eth 10100000.ethernet eth0: rx_ring=0, base=077cc000, max=1024, calc=268, drx=273
Sun Oct 4 09:27:19 2020 kern.err kernel: [ 598.096437] mtk_soc_eth 10100000.ethernet eth0: transmit timed out
Sun Oct 4 09:27:19 2020 kern.info kernel: [ 598.102736] mtk_soc_eth 10100000.ethernet eth0: dma_cfg:00000055
Sun Oct 4 09:27:19 2020 kern.info kernel: [ 598.108871] mtk_soc_eth 10100000.ethernet eth0: tx_ring=0, base=07144000, max=1024, ctx=19, dtx=19, fdx=958, next=19
Sun Oct 4 09:27:19 2020 kern.info kernel: [ 598.119566] mtk_soc_eth 10100000.ethernet eth0: rx_ring=0, base=077f4000, max=1024, calc=854, drx=855
Sun Oct 4 09:41:39 2020 kern.err kernel: [ 1458.091007] mtk_soc_eth 10100000.ethernet eth0: transmit timed out
Sun Oct 4 09:41:39 2020 kern.info kernel: [ 1458.097300] mtk_soc_eth 10100000.ethernet eth0: dma_cfg:00000055
Sun Oct 4 09:41:39 2020 kern.info kernel: [ 1458.103430] mtk_soc_eth 10100000.ethernet eth0: tx_ring=0, base=07144000, max=1024, ctx=619, dtx=619, fdx=604, next=619
Sun Oct 4 09:41:39 2020 kern.info kernel: [ 1458.114389] mtk_soc_eth 10100000.ethernet eth0: rx_ring=0, base=077b8000, max=1024, calc=299, drx=300
Sun Oct 4 09:41:49 2020 kern.err kernel: [ 1468.090982] mtk_soc_eth 10100000.ethernet eth0: transmit timed out
Sun Oct 4 09:41:49 2020 kern.info kernel: [ 1468.097283] mtk_soc_eth 10100000.ethernet eth0: dma_cfg:00000055
Sun Oct 4 09:41:49 2020 kern.info kernel: [ 1468.103419] mtk_soc_eth 10100000.ethernet eth0: tx_ring=0, base=07144000, max=1024, ctx=243, dtx=243, fdx=199, next=243
Sun Oct 4 09:41:49 2020 kern.info kernel: [ 1468.114377] mtk_soc_eth 10100000.ethernet eth0: rx_ring=0, base=077f4000, max=1024, calc=913, drx=914
Sun Oct 4 09:42:29 2020 kern.err kernel: [ 1508.090740] mtk_soc_eth 10100000.ethernet eth0: transmit timed out
Sun Oct 4 09:42:29 2020 kern.info kernel: [ 1508.097032] mtk_soc_eth 10100000.ethernet eth0: dma_cfg:00000055
Sun Oct 4 09:42:29 2020 kern.info kernel: [ 1508.103169] mtk_soc_eth 10100000.ethernet eth0: tx_ring=0, base=07144000, max=1024, ctx=291, dtx=291, fdx=253, next=291
Sun Oct 4 09:42:29 2020 kern.info kernel: [ 1508.114129] mtk_soc_eth 10100000.ethernet eth0: rx_ring=0, base=077b8000, max=1024, calc=804, drx=806
Sun Oct 4 09:42:44 2020 kern.err kernel: [ 1523.050596] mtk_soc_eth 10100000.ethernet eth0: transmit timed out
Sun Oct 4 09:42:44 2020 kern.info kernel: [ 1523.056890] mtk_soc_eth 10100000.ethernet eth0: dma_cfg:00000055
Sun Oct 4 09:42:44 2020 kern.info kernel: [ 1523.063018] mtk_soc_eth 10100000.ethernet eth0: tx_ring=0, base=077f4000, max=1024, ctx=725, dtx=725, fdx=672, next=725
Sun Oct 4 09:42:44 2020 kern.info kernel: [ 1523.073977] mtk_soc_eth 10100000.ethernet eth0: rx_ring=0, base=0728c000, max=1024, calc=327, drx=328
Sun Oct 4 09:42:58 2020 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED 2c:fd:a1:60:c9:7c
Sun Oct 4 09:42:58 2020 daemon.info hostapd: wlan0: STA 2c:fd:a1:60:c9:7c IEEE 802.11: disassociated due to inactivity
Sun Oct 4 09:42:59 2020 daemon.info hostapd: wlan0: STA 2c:fd:a1:60:c9:7c IEEE 802.11: deauthenticated due to inactivity (timer DEAUTH/REMOVE)
Sun Oct 4 09:46:32 2020 daemon.info hostapd: wlan0: STA 2c:fd:a1:60:c9:7c IEEE 802.11: authenticated
Sun Oct 4 09:46:32 2020 daemon.info hostapd: wlan0: STA 2c:fd:a1:60:c9:7c IEEE 802.11: associated (aid 2)
Sun Oct 4 09:46:32 2020 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 2c:fd:a1:60:c9:7c
Sun Oct 4 09:46:32 2020 daemon.info hostapd: wlan0: STA 2c:fd:a1:60:c9:7c WPA: pairwise key handshake completed (RSN)
Sun Oct 4 09:46:32 2020 daemon.info dnsmasq-dhcp[1469]: DHCPREQUEST(br-lan) 192.168.8.147 2c:fd:a1:60:c9:7c
Sun Oct 4 09:46:32 2020 daemon.info dnsmasq-dhcp[1469]: DHCPACK(br-lan) 192.168.8.147 2c:fd:a1:60:c9:7c stokito-serv
Sun Oct 4 09:46:34 2020 daemon.info dnsmasq[1469]: read /etc/hosts - 4 addresses
Sun Oct 4 09:46:34 2020 daemon.info dnsmasq[1469]: read /tmp/hosts/odhcpd - 3 addresses
Sun Oct 4 09:46:34 2020 daemon.info dnsmasq[1469]: read /tmp/hosts/dhcp.cfg01411c - 6 addresses
Sun Oct 4 09:46:34 2020 daemon.info dnsmasq-dhcp[1469]: read /etc/ethers - 0 addresses
Sun Oct 4 09:46:49 2020 kern.err kernel: [ 1768.088961] mtk_soc_eth 10100000.ethernet eth0: transmit timed out
Sun Oct 4 09:46:49 2020 kern.info kernel: [ 1768.095252] mtk_soc_eth 10100000.ethernet eth0: dma_cfg:00000055
Sun Oct 4 09:46:49 2020 kern.info kernel: [ 1768.101387] mtk_soc_eth 10100000.ethernet eth0: tx_ring=0, base=077f4000, max=1024, ctx=54, dtx=54, fdx=22, next=54
Sun Oct 4 09:46:49 2020 kern.info kernel: [ 1768.111996] mtk_soc_eth 10100000.ethernet eth0: rx_ring=0, base=077b8000, max=1024, calc=245, drx=247
Sun Oct 4 09:46:59 2020 kern.err kernel: [ 1778.088873] mtk_soc_eth 10100000.ethernet eth0: transmit timed out
Sun Oct 4 09:46:59 2020 kern.info kernel: [ 1778.095167] mtk_soc_eth 10100000.ethernet eth0: dma_cfg:00000055
Sun Oct 4 09:46:59 2020 kern.info kernel: [ 1778.101295] mtk_soc_eth 10100000.ethernet eth0: tx_ring=0, base=077f4000, max=1024, ctx=400, dtx=400, fdx=256, next=400
Sun Oct 4 09:46:59 2020 kern.info kernel: [ 1778.112257] mtk_soc_eth 10100000.ethernet eth0: rx_ring=0, base=0728c000, max=1024, calc=575, drx=576
Sun Oct 4 09:55:34 2020 kern.err kernel: [ 2293.044972] mtk_soc_eth 10100000.ethernet eth0: transmit timed out
Sun Oct 4 09:55:34 2020 kern.info kernel: [ 2293.051265] mtk_soc_eth 10100000.ethernet eth0: dma_cfg:00000055
Sun Oct 4 09:55:34 2020 kern.info kernel: [ 2293.057394] mtk_soc_eth 10100000.ethernet eth0: tx_ring=0, base=077b8000, max=1024, ctx=254, dtx=254, fdx=226, next=254
Sun Oct 4 09:55:34 2020 kern.info kernel: [ 2293.068351] mtk_soc_eth 10100000.ethernet eth0: rx_ring=0, base=0728c000, max=1024, calc=373, drx=374
Sun Oct 4 09:55:44 2020 kern.err kernel: [ 2303.044916] mtk_soc_eth 10100000.ethernet eth0: transmit timed out
Sun Oct 4 09:55:44 2020 kern.info kernel: [ 2303.051207] mtk_soc_eth 10100000.ethernet eth0: dma_cfg:00000055
Sun Oct 4 09:55:44 2020 kern.info kernel: [ 2303.057338] mtk_soc_eth 10100000.ethernet eth0: tx_ring=0, base=077b8000, max=1024, ctx=574, dtx=574, fdx=502, next=574
Sun Oct 4 09:55:44 2020 kern.info kernel: [ 2303.068305] mtk_soc_eth 10100000.ethernet eth0: rx_ring=0, base=077f4000, max=1024, calc=992, drx=993
Sun Oct 4 09:55:54 2020 kern.err kernel: [ 2313.044815] mtk_soc_eth 10100000.ethernet eth0: transmit timed out
Sun Oct 4 09:55:54 2020 kern.info kernel: [ 2313.051108] mtk_soc_eth 10100000.ethernet eth0: dma_cfg:00000055
Sun Oct 4 09:55:54 2020 kern.info kernel: [ 2313.057234] mtk_soc_eth 10100000.ethernet eth0: tx_ring=0, base=077b8000, max=1024, ctx=182, dtx=182, fdx=176, next=182
Sun Oct 4 09:55:54 2020 kern.info kernel: [ 2313.068193] mtk_soc_eth 10100000.ethernet eth0: rx_ring=0, base=0728c000, max=1024, calc=675, drx=676
Sun Oct 4 09:59:46 2020 daemon.notice hostapd: wlan0: AP-STA-DISCONNECTED 8c:70:5a:46:aa:4c
Sun Oct 4 09:59:46 2020 daemon.info hostapd: wlan0: STA 8c:70:5a:46:aa:4c IEEE 802.11: authenticated
Sun Oct 4 09:59:46 2020 daemon.info hostapd: wlan0: STA 8c:70:5a:46:aa:4c IEEE 802.11: associated (aid 6)
Sun Oct 4 09:59:46 2020 daemon.notice hostapd: wlan0: AP-STA-CONNECTED 8c:70:5a:46:aa:4c
Sun Oct 4 09:59:46 2020 daemon.info hostapd: wlan0: STA 8c:70:5a:46:aa:4c WPA: pairwise key handshake completed (RSN)
Sun Oct 4 10:02:49 2020 kern.err kernel: [ 2728.081761] mtk_soc_eth 10100000.ethernet eth0: transmit timed out
Sun Oct 4 10:02:49 2020 kern.info kernel: [ 2728.088058] mtk_soc_eth 10100000.ethernet eth0: dma_cfg:00000055
Sun Oct 4 10:02:49 2020 kern.info kernel: [ 2728.094190] mtk_soc_eth 10100000.ethernet eth0: tx_ring=0, base=077f4000, max=1024, ctx=332, dtx=332, fdx=315, next=332
Sun Oct 4 10:02:49 2020 kern.info kernel: [ 2728.105148] mtk_soc_eth 10100000.ethernet eth0: rx_ring=0, base=07144000, max=1024, calc=409, drx=410
Sun Oct 4 10:02:59 2020 kern.err kernel: [ 2738.081739] mtk_soc_eth 10100000.ethernet eth0: transmit timed out
Sun Oct 4 10:02:59 2020 kern.info kernel: [ 2738.088032] mtk_soc_eth 10100000.ethernet eth0: dma_cfg:00000055
Sun Oct 4 10:02:59 2020 kern.info kernel: [ 2738.094168] mtk_soc_eth 10100000.ethernet eth0: tx_ring=0, base=077f4000, max=1024, ctx=284, dtx=284, fdx=275, next=284
Sun Oct 4 10:02:59 2020 kern.info kernel: [ 2738.105124] mtk_soc_eth 10100000.ethernet eth0: rx_ring=0, base=077b8000, max=1024, calc=411, drx=412
Sun Oct 4 10:09:14 2020 kern.err kernel: [ 3113.038938] mtk_soc_eth 10100000.ethernet eth0: transmit timed out
Sun Oct 4 10:09:14 2020 kern.info kernel: [ 3113.045238] mtk_soc_eth 10100000.ethernet eth0: dma_cfg:00000055
Sun Oct 4 10:09:14 2020 kern.info kernel: [ 3113.051375] mtk_soc_eth 10100000.ethernet eth0: tx_ring=0, base=077f4000, max=1024, ctx=83, dtx=83, fdx=31, next=83
Sun Oct 4 10:09:14 2020 kern.info kernel: [ 3113.061981] mtk_soc_eth 10100000.ethernet eth0: rx_ring=0, base=07144000, max=1024, calc=257, drx=258
Sun Oct 4 10:09:24 2020 kern.err kernel: [ 3123.038849] mtk_soc_eth 10100000.ethernet eth0: transmit timed out
Sun Oct 4 10:09:24 2020 kern.info kernel: [ 3123.045142] mtk_soc_eth 10100000.ethernet eth0: dma_cfg:00000055
Sun Oct 4 10:09:24 2020 kern.info kernel: [ 3123.051272] mtk_soc_eth 10100000.ethernet eth0: tx_ring=0, base=077b8000, max=1024, ctx=561, dtx=561, fdx=508, next=561
Sun Oct 4 10:09:24 2020 kern.info kernel: [ 3123.062229] mtk_soc_eth 10100000.ethernet eth0: rx_ring=0, base=0728c000, max=1024, calc=989, drx=990
Sun Oct 4 10:10:59 2020 kern.err kernel: [ 3218.078075] mtk_soc_eth 10100000.ethernet eth0: transmit timed out
Sun Oct 4 10:10:59 2020 kern.info kernel: [ 3218.084366] mtk_soc_eth 10100000.ethernet eth0: dma_cfg:00000055
Sun Oct 4 10:10:59 2020 kern.info kernel: [ 3218.090497] mtk_soc_eth 10100000.ethernet eth0: tx_ring=0, base=077f4000, max=1024, ctx=561, dtx=561, fdx=525, next=561
Sun Oct 4 10:10:59 2020 kern.info kernel: [ 3218.101455] mtk_soc_eth 10100000.ethernet eth0: rx_ring=0, base=073c4000, max=1024, calc=534, drx=535
Sun Oct 4 10:11:29 2020 kern.err kernel: [ 3248.077879] mtk_soc_eth 10100000.ethernet eth0: transmit timed out
Sun Oct 4 10:11:29 2020 kern.info kernel: [ 3248.084173] mtk_soc_eth 10100000.ethernet eth0: dma_cfg:00000055
Sun Oct 4 10:11:29 2020 kern.info kernel: [ 3248.090300] mtk_soc_eth 10100000.ethernet eth0: tx_ring=0, base=077b8000, max=1024, ctx=374, dtx=374, fdx=303, next=374
Sun Oct 4 10:11:29 2020 kern.info kernel: [ 3248.101261] mtk_soc_eth 10100000.ethernet eth0: rx_ring=0, base=07144000, max=1024, calc=729, drx=730
Sun Oct 4 10:12:04 2020 daemon.err uhttpd[977]: luci: accepted login on / for root from 192.168.8.147
But then wifi works well and I decided to write my expirience here
