MT6000 slows down 5Ghz connection after some time
Just found more devices with the same issue:
Couple of USB wifi adapters
Orange pi zero 3
Firmware 4.6.2 fix the issue for then too.
Please update this in the next release version.
Waiting for a firmware update too.. The beta does not solve the problem.
The codes has been updated, please wait for the beta version firmware to be released.
Excellent, that's great to hear :slight_smile:
Think I have this issue too actually with some devices (Mainly android by the looks of it?) on the 2.4GHZ channel.
For no reason whatsoever, they drop from 50-70mbps on a speed test to 1-15mbps.
Galaxy Tab A9 - Wi-Fi 802.11 a/b/g/n/ac, dual-band
Nokia T10 - Wi-Fi 802.11 a/b/g/n/ac, dual-band
Are there any downside to flashing 4.6.2? Can i flash over the top of 4.7.0 without losing all my settings etc?
Is there any update on when a BETA FW is being released?
No downside, the only thing you'll lose is Astrowarp integration. If you don't use it, try to downgrade. You can just upgrade again without losing data.
Tried it briefly, but it all still felt a bit off.
Would it be wise to flash and leave it a while to 'settle'
4.7.0 feels the most stable for me in terms of consistent speeds/signal strength.
4.6.2 - Feels slow. Speed tests show this.
If we can get some clarification on when this next BETA will drop with updates changes, that'd be great. @bruce
Otherwise, it might be that i just return this and go back to my previous ASUS Mesh setup. At least that just 'Worked'
We will release the beta version with the repair codes asap, I assume within these weeks.
Excellent. Hopefully that fixes the issues!
This issue is fixed on v4.7.4 (or later) firmware.
Yes I can confirm!
