Looking for some help. I bought an esim from Orange Romania. I installed it with no problem outside Romania. Now I’m in Romania, the esim won’t connect and gives the error message (attached also).
Connection failed...
eSIM unregistered. Please check in eSIM Management whether the eSIM profile is enabled or requires Top-up , or contact your eSIM provider to confirm any special restrictions, and verify that the APN settings are correct. Current APN: net Network Troubleshooting Guide
If the issue persists, please download the logs and send them to support@gl-inet.com .
There is a full Orange signal available on my iPhone and I’ve tried this at several locations.
Did you remain the router configuration when performing firmware upgrade? If so, I suggest to try a factory reset.
If issue persists, could you share device to support through Goodcloud for remote troubleshooting: Technical Support via GoodCloud - GL.iNet Router Docs 4
