Anyone able to get Visible Wireless working? I just signed up based on a few threads but thinking maybe that was a mistake. From what I can tell I have the Visible+ Plan and it’s just throttling to 10Mbps which matches what Visble+ advertises as the hotspot speed. Any way to circumvent this? I’ve tried spoofing the IMEI to that of an iPhone. I got unlocked speeds only once after I put the SIM in said iPhone and moved it back to the Mudi 7. I rebooted and those speeds did not stick and it revered back to the 10Mbps throttled speed. Should I just look for a different carrier?
Try to set TTL to 65 in SIM Card Settings
Yeah no luck unfortunately. On the other hand does anyone know how factory reset all the changes I’ve made to the modem? I know the IMEI will retain but probably should start from scratch with everything else.
Have you made any progress?
No, I gave up and just added a line (tablet line) with AT&T. I think that should work but will report back if it doesn’t. It ended up being cheaper if it does work. Visible did give me a complete refund since I only had the service for a few days, so props to them for that.
TTL/HL 64 works fine for me. Did you try that?
