Mudi 7 - WiFi goes off on 24/7
i’m using the device as 24/7 Router with usbc power cable on vacation.
after some hours and every morning i need to press the home button for wifi ssid’s come back visible.
what can i check?
best regards,
daniel
The Mudi 7 includes an Idle Timeout / Standby feature that can automatically disable Wi-Fi when it is idle, helping to reduce power consumption when the device is running on battery power.
If the device is always connected to an external power source, or if you prefer not to use this feature, you can adjust the settings under Admin Panel → System → USB & Power according to your needs.
For more details, please refer to the following documentation:
Oh, how could I have missed that setting?
Perfect—thanks!
