Mudi/E750 Firmware 4.x does not auto boot on power
With Version 3.x of the firmware, the Mudi/E750 would auto boot if it was off and if power was applied.
With Version 4.x this does not happen. I have tested this with both a Musd V1 and a Mudi V2 with 4.x firmware and the results are the same.
Can anyone point me in the right direction to ensure so that a Mudi when switched off will automatically boot when under power?
Can you try this for the E750V2?
ubus call mcu send_custom_msg {\"auto_start\":\"1\"}
That worked! Thank you very much :slight_smile:
