Just tested the sms forwarding with multiple email account, but it looks like the Mudi only sends out a email, that it received the sms. The forwarded email doesn’t include the sms text. It looks like the functions not working correctly.
According to the FAQ it should send the text as well. Or did I set up something wrong?
I tried gmail (both port 465 and 587 work) and my personal email-server. Both work and send out the confirmation email and the forwarded emails, but the sms text is missing in all of them.
Here is one send through my gmail account. Included the original full email data. Just removed some part of the phone number.
And a second example send through my personal email server.
1.) Example
> Bcc: dmittag@gmail.com
> Return-Path: <dmittag@gmail.com>
> Received: from gmail.com ([58.64.26.6])
> by smtp.gmail.com with ESMTPSA id lf4sm3462949pjb.0.2021.02.03.18.29.30
> for <dmittag@gmail.com>
> (version=TLS1_3 cipher=TLS_CHACHA20_POLY1305_SHA256 bits=256/256);
> Wed, 03 Feb 2021 18:29:32 -0800 (PST)
> Message-ID: <601b5c0c.1c69fb81.e3f37.88d7@mx.google.com>
> Received: by gmail.com (sSMTP sendmail emulation); Thu, 04 Feb 2021 03:29:28 +0100
> Date: Thu, 04 Feb 2021 03:29:28 +0100
> From: dmittag@gmail.com
> Subject: Gl-iNet Mudi SMS-Forward received a message from 1315818xxxx
> Content-Type: text/html;charset=UTF-8
Could you also provide the content of SMS text? Some kinds of content may fail when converting encoding format. Also, which firmware version are you using?
From your screenshot, something was wrong when receiving the SMS, could you login to the router via SSH and show me the full SMS content? It should be in /etc/spool/sms/storage/.
Apparently, the transcoding process is ok, and the extra data shouldn’t be the cause.
May I have a remote check? You can add my skype if possible : 342800903@qq.com
