MUDI (GL-E750 w/ EP06-E) battery swollen
Hey all!
My Mudi’s battery has recently swollen, actually while the device was running. Any ideas where to get replacements?
Please contact customer support cs@gl-inet.com with order details.
Is there a way to set max charge level to 70-80% to reduce battery wear from always being at 100%?
Sorry that’s not supported.
Could you consider adding such a feature?
That’s due to the current hardware MCU type. Not sure about the future version.
Can charging be disabled somehow? Removing the battery shows an X on the battery icon
There is no disabled method, the display X indicates that the battery is not recognized, It still works when connected to a power source.
so you replace batteries?
i bought on amazon
No, contact customer support, please. I’m not familiar with that operation.
