Mudi ar 750 reaches temperature 71C at 5 minutes and shut down on its own . What can I do ?
Seems it has a problem. Temperature should not go that fast and that high.
Can you let me know if it was working good? or it is brand new?
Is the environment temperature ok?
Be sure not to put it inside your bag or under sunshine while using.
It’s a new one ,used to work ok. How do I contact the tech support?
