I’ve tried to use tor connection,
There is initialisation and then process stucked at 25%
See screenshot
If you are getting stuck at 25%, your ISP might be blocking the connection to TOR. If you can try another ISP or connect to a wifi hotspot and try.
Tor is not blocked by cellular operator,
It’s opens without any problems using PC+Mudi
