Mudi v1 - 5GHz + firmware update
Hi, I have a problem with 5GHz network as it sometimes simply disappears when I try to search for a network. I have to wait like 3 times/refreshes on Android devices when searching for network. No problem with Windows PC.
One more thing, did you do something about the battery? Was something touched in this direction? Normally before the update device would simply turn off when I would charge it and use. Now temps are a bit lower and while it of course still gets hot, it doesn't turn off. Same weather and conditions.
That's normal since you use DFS channels: Dynamic frequency selection - Wikipedia
Depending on your country you should use some non-DFS channels, check the link above.
I'm using channel 36 and I'm from EU, it's a non-DFS channel
