My Mudi v2 esim menu is gone and the esim is inserted, was working today since i just received it and i installed a new esim to test the functionality.
please advice.
Did you power cycle the device already?
Yes I did restart few times and I did try to deactivate 4g and use it as extender thinking maybe was not showing because eSIM was in use.
To be sure I reset the firmware and restart and same behavior, in the application I cannot see the eSIM management. Any idea? Can the eSIM app be reinstalled or something ?
Hi!
Could you please execute this command in the background and post the result?
curl -s -X POST -H 'Content-Type: application/json' -d '{"method": "prod"}' http://localhost:3456/sdk/v1
By the way, is your physical esim card bought from webbing?
I had this problem; it was fixed by installing beta firmware.
https://dl.gl-inet.com/release/router/testing/e750/4.3.21
Release Notes # V4.3.21_beta1
Bug Fixes * Fixed the problem that esim manage page is lost after installing some esim profiles.
