MUDI V2 Router setup for Visible sim/esim
I just bought a MUDI V2 and will be setting it up on Visible. This tutorial will apply to almost any LTE router, as long as it's running OpenWRT as it's OS I'll cover everything from APN creation and Router Configuration using AT Commands. I'll show you the proper way to reboot your routers so settings take effect
Properly and I'll go over how to update and upgrade firmware if that's also something you need help with. I don't know what LTE module or which Version of OpenWRT it's been shiped with. I'm going to add ufl type antennas and increase it's LTE coverage and will end the tutorial with connecting to the router over SSH and will properly mangle the TTL for unlimited devices to use the Hotspot hopefully none of this has been patched in anyway because I haven't used this hardware setup in about 16 months.
Follow this Topic and by tomorrow July 21st 2025 I will have completed everything in this setup guide and I have a couple things I'm working on that I'm not going to talk about here. But if you like Pineapples I'm going to convert my MUDI into a Pineapple that has its own power supply and Internet connection something OG Pineapples don't come with now how dope is that?
Come check out this Topic tomorrow because I've been down these forums posts on quite a few websites and there's always tons of confusion with setting up simcards on LTE routers and getting it all to just "Work" the first time.
