Mudi v2 vs v1 charging
Are there any changes to the battery and charging than the Mudi v1?
Can the charging level be adjusted to something like 70% from the MCU?
Did the v2 fix the battery bulging issue?
Hi, Mudi V2 comes with new battery, the charging time should be shorter than Mudi V1 and the battery life would be longer. It doesn't support to change the charging level at present.
We haven't received the feedback that v2 has battery bulging issue. To keep the battery health and protect the battery, here are some recommendation for your reference
  1. It is recommended to use the original charger when charging;
  2. Try to avoid placing in high temperature places, such as outdoor cars, open flame areas
  3. Do not remove the battery or modify the router.
  4. Avoid external influences, such as falling, piercing, bumping, etc.
  5. Avoid overcharging and over discharging.
Thanks, Can the MCU in the v2 control the charge level with a firmware upgrade in the future or will this need to be another new version like v3?
Not sure about it. But we'll consider your requirements. I'll feedback to the PM
I vote for this feature too. @yuxin.zou
What I would like to see is an option to set a custom lower and higher limit like 60% to 80% where the MCU will charge to 80% and will not charge until the battery drops below 60%.
The hardware controller doesn't support ...... it can't be upgraded with firmware.
We may consider this for our new products in the future.
