MudiV2 4.8.3 beta issues (VPN not detected)
I encountered a VPN detection problem with version 4.8.3 Beta on MudiV2
Although the VPN connection is established (when launched via the web panel), the VPN icon does not appear on the LCD screen.
The kill switch is enabled by default, blocking all connections until it is disabled, even when the VPN is up.
We are aware of this issue and will submit it to R&D for inspection.
Thank you for your feedback!
