Multiple Clients connecting to 1 Server?
I have an Opal (as Server) and a Slate (as the client) running Wireguard to use my home IP for when I am away. But was wondering can I use another client (say a 2nd Slate) if my wife is in another location other than me, connecting to the same Server, simultaneously? Would I just set it up using the same Config file/settings I did for the 1st Slate? Thanks in advance.
I don’t see why not but… as said before, dry run before heading out ‘in the wild.’
Thank You! Will attempt and let all know.
