Hey Everyone, my Brume seems to be dropping internet connection. The logs show my interfaces as going down. I have vlans enabled, working fine for months.
I tried swapping my smart switch, but same issue. I dont know what else to look at.
I thought maybe my VPN provider, so I disabled the VPN service on my Brume, but no luck.
I’m on version: 3.203
Logs:
Fri Apr 15 16:44:27 2022 kern.info kernel: [108547.302268] mv88e6085 d0032004.mdio-mii:01 lan0: Link is Down
Fri Apr 15 16:44:27 2022 kern.info kernel: [108547.308649] br-lan: port 1(lan0) entered disabled state
Fri Apr 15 16:44:27 2022 daemon.notice netifd: Network device 'lan0' link is down
Fri Apr 15 16:44:27 2022 daemon.notice netifd: Interface 'lan0' has link connectivity loss
Fri Apr 15 16:44:27 2022 daemon.notice netifd: Interface 'lan0' is now down
Fri Apr 15 16:44:27 2022 daemon.notice netifd: VLAN 'lan0.5' link is down
Fri Apr 15 16:44:27 2022 kern.info kernel: [108547.321064] br-DMZ: port 1(lan0.5) entered disabled state
Fri Apr 15 16:44:28 2022 daemon.notice netifd: bridge 'br-lan' link is down
Fri Apr 15 16:44:28 2022 daemon.notice netifd: Interface 'lan' has link connectivity loss
Fri Apr 15 16:44:28 2022 daemon.notice netifd: bridge 'br-DMZ' link is down
Fri Apr 15 16:44:28 2022 daemon.notice netifd: Interface 'DMZ' has link connectivity loss
Fri Apr 15 16:44:41 2022 kern.info kernel: [108560.823652] mv88e6085 d0032004.mdio-mii:01 lan0: Link is Up - 1Gbps/Full - flow control off
Fri Apr 15 16:44:41 2022 kern.info kernel: [108560.832720] br-lan: port 1(lan0) entered blocking state
Fri Apr 15 16:44:41 2022 kern.info kernel: [108560.838352] br-lan: port 1(lan0) entered forwarding state
Fri Apr 15 16:44:41 2022 daemon.notice netifd: Network device 'lan0' link is up
Fri Apr 15 16:44:41 2022 daemon.notice netifd: Interface 'lan0' has link connectivity
Fri Apr 15 16:44:41 2022 daemon.notice netifd: Interface 'lan0' is setting up now
Fri Apr 15 16:44:41 2022 kern.info kernel: [108560.847281] br-DMZ: port 1(lan0.5) entered blocking state
Fri Apr 15 16:44:41 2022 kern.info kernel: [108560.852723] br-DMZ: port 1(lan0.5) entered forwarding state
Fri Apr 15 16:44:41 2022 daemon.notice netifd: Interface 'lan0' is now up
Fri Apr 15 16:44:41 2022 daemon.notice netifd: bridge 'br-lan' link is up
Fri Apr 15 16:44:41 2022 daemon.notice netifd: Interface 'lan' has link connectivity
Fri Apr 15 16:44:41 2022 daemon.notice netifd: VLAN 'lan0.5' link is up
Fri Apr 15 16:44:41 2022 daemon.notice netifd: bridge 'br-DMZ' link is up
Fri Apr 15 16:44:41 2022 daemon.notice netifd: Interface 'DMZ' has link connectivity
Fri Apr 15 16:44:41 2022 user.info mwan3rtmon[2493]: Detect rtchange event.
Fri Apr 15 16:44:41 2022 user.notice wrtbwmon: Restart for ifup of lan0 (lan0)
