NAT64 - Missing kmod-jool on GL-AX1800
The package kmod-jool or kmod-jool-netfilter is missing from the package repository. This prevent NAT64 and is a critical bug to my point of view, the whole network is down.
In compilation, will upload to the GL feed.
Thank you for the support and addressing the issue so fast. I can confirm the kmod-jool package is now available.
I get some error enabling the module:
root@b-r0:~# modprobe jool
modprobe: FATAL: Module jool not found in directory /lib/modules/4.4.60
root@b-r0:~# lsmod | grep jool | head -n1
jool                    1345  0
root@b-r0:~# ls -la /lib/modules/4.4.60/jool.ko
-rw-r--r--    1 root     root          4680 Apr  6  2021 /lib/modules/4.4.60/jool.ko
GL have not tried this plugin, and probably cannot tech support for this plugin.
May I know if it lacks other dependence plugin?
I was able to install it on my device, or you try using the insmod command
insmod /lib/modules/4.4.60/jool.ko
Thanks pan.li forgot about insmod. It did the trick.
