Need help with mount points - AR750S
as the router always crashes and reboots when i try to copy or stream big video-files, I switched the mount point of the SD-Card from /tmp/mountd/disk1_part1 to /mnt/SD256. But now it is not possible to use it with samba. Is mnt the wrong directory to use for mount points?
samba3
Nah, it’s fine, but then you have to do the samba config by yourself.
Mixing GL GUI and luci things is - generally speaking - not recommended.
Ah ok. I understand.
Is there any way to prevent from the crash and reboot behaviour with the standard settings (/tmp/mountd/disk1_part1)?
I think samba config by myself is to difficult for me. :grimacing:
The main question would be: Why does it crash and reboot?
May you post the log files?
Here comes a part of the system.log. The rebbot was at ~20:45. Dont know which lines are important…
Sat Dec 16 20:31:42 2023 daemon.info dnsmasq[1]: started, version 2.86 cachesize 150
Sat Dec 16 20:31:42 2023 daemon.info dnsmasq[1]: DNS service limited to local subnets
Sat Dec 16 20:31:42 2023 daemon.info dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Sat Dec 16 20:31:42 2023 daemon.info dnsmasq[1]: UBus support enabled: connected to system bus
Sat Dec 16 20:31:42 2023 daemon.info dnsmasq[1]: using nameserver 52.29.2.17#53
Sat Dec 16 20:31:42 2023 daemon.info dnsmasq[1]: using nameserver 3.10.65.124#53
Sat Dec 16 20:31:42 2023 daemon.info dnsmasq[1]: using only locally-known addresses for test
Sat Dec 16 20:31:42 2023 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Sat Dec 16 20:31:42 2023 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Sat Dec 16 20:31:42 2023 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Sat Dec 16 20:31:42 2023 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Sat Dec 16 20:31:42 2023 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Sat Dec 16 20:31:42 2023 daemon.info dnsmasq[1]: read /etc/hosts - 4 addresses
Sat Dec 16 20:31:42 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 2 addresses
Sat Dec 16 20:31:42 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:31:42 2023 authpriv.info dropbear[3573]: Not backgrounding
Sat Dec 16 20:31:43 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:31:44 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:31:45 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:31:46 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:31:46 2023 daemon.notice procd: /etc/rc.d/S19firewall: iptables v1.8.7 (nf_tables): Chain ‘VPN_SER_POLICY’ does not exist
Sat Dec 16 20:31:46 2023 daemon.notice procd: /etc/rc.d/S19firewall: Try `iptables -h’ or ‘iptables --help’ for more information.
Sat Dec 16 20:31:46 2023 daemon.notice procd: /etc/rc.d/S19firewall: iptables: No chain/target/match by that name.
Sat Dec 16 20:31:47 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:31:48 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:31:49 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:31:50 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:31:50 2023 daemon.notice wpa_supplicant[3853]: Successfully initialized wpa_supplicant
Sat Dec 16 20:31:51 2023 user.notice : Added device handler type: bonding
Sat Dec 16 20:31:51 2023 user.notice : Added device handler type: 8021ad
Sat Dec 16 20:31:51 2023 user.notice : Added device handler type: 8021q
Sat Dec 16 20:31:51 2023 user.notice : Added device handler type: macvlan
Sat Dec 16 20:31:51 2023 user.notice : Added device handler type: veth
Sat Dec 16 20:31:51 2023 user.notice : Added device handler type: bridge
Sat Dec 16 20:31:51 2023 user.notice : Added device handler type: Network device
Sat Dec 16 20:31:51 2023 user.notice : Added device handler type: tunnel
Sat Dec 16 20:31:51 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:31:53 2023 daemon.notice procd: /etc/rc.d/S40gl_nas_diskmanager: start app = /usr/bin/gl_nas_diskmanager
Sat Dec 16 20:31:59 2023 daemon.notice ntfs-3g[4523]: Version 2021.8.22 integrated FUSE 27
Sat Dec 16 20:31:59 2023 daemon.notice ntfs-3g[4523]: Mounted /dev/sda1 (Read-Write, label “”, NTFS 3.1)
Sat Dec 16 20:31:59 2023 daemon.notice ntfs-3g[4523]: Cmdline options: noatime,big_writes,async,force
Sat Dec 16 20:31:59 2023 daemon.notice ntfs-3g[4523]: Mount options: async,force,allow_other,nonempty,noatime,fsname=/dev/sda1,blkdev,blksize=4096
Sat Dec 16 20:31:59 2023 daemon.notice ntfs-3g[4523]: Ownership and permissions disabled, configuration type 1
Sat Dec 16 20:32:01 2023 daemon.info avahi-daemon[4572]: Found user ‘nobody’ (UID 65534) and group ‘nogroup’ (GID 65534).
Sat Dec 16 20:32:01 2023 daemon.info avahi-daemon[4572]: Successfully dropped root privileges.
Sat Dec 16 20:32:01 2023 daemon.info avahi-daemon[4572]: avahi-daemon 0.8 starting up.
Sat Dec 16 20:32:01 2023 daemon.warn avahi-daemon[4572]: WARNING: No NSS support for mDNS detected, consider installing nss-mdns!
Sat Dec 16 20:32:02 2023 daemon.info avahi-daemon[4572]: No service file found in /etc/avahi/services.
Sat Dec 16 20:32:02 2023 daemon.info avahi-daemon[4572]: Network interface enumeration completed.
Sat Dec 16 20:32:02 2023 daemon.info avahi-daemon[4572]: Registering HINFO record with values ‘MIPS’/‘LINUX’.
Sat Dec 16 20:32:02 2023 daemon.info avahi-daemon[4572]: Server startup complete. Host name is GL-AR750S.local. Local service cookie is 3128470844.
Sat Dec 16 20:32:03 2023 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/network
Sat Dec 16 20:32:03 2023 user.notice ucitrack: Setting up /etc/config/network reload dependency on /etc/config/wireless
Sat Dec 16 20:32:04 2023 user.notice ucitrack: Setting up /etc/config/luci-splash reload dependency on /etc/config/firewall
Sat Dec 16 20:32:04 2023 user.notice ucitrack: Setting up /etc/config/qos reload dependency on /etc/config/firewall
Sat Dec 16 20:32:04 2023 user.notice ucitrack: Setting up /etc/config/miniupnpd reload dependency on /etc/config/firewall
Sat Dec 16 20:32:05 2023 user.notice ucitrack: Setting up /etc/config/odhcpd reload dependency on /etc/config/dhcp
Sat Dec 16 20:32:06 2023 user.notice ucitrack: Setting up non-init /etc/config/fstab reload handler: /sbin/block mount
Sat Dec 16 20:32:07 2023 user.notice ucitrack: Setting up /etc/config/system reload trigger for non-procd /etc/init.d/led
Sat Dec 16 20:32:07 2023 user.notice ucitrack: Setting up /etc/config/luci_statistics reload dependency on /etc/config/system
Sat Dec 16 20:32:07 2023 user.notice ucitrack: Setting up /etc/config/dhcp reload dependency on /etc/config/system
Sat Dec 16 20:32:11 2023 kern.info kernel: [ 94.702692] tertf: br-lan registered, add it
Sat Dec 16 20:32:11 2023 kern.info kernel: [ 94.744473] eth0: link up (1000Mbps/Full duplex)
Sat Dec 16 20:32:11 2023 kern.info kernel: [ 94.772625] device eth0 entered promiscuous mode
Sat Dec 16 20:32:11 2023 kern.info kernel: [ 94.778080] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sat Dec 16 20:32:11 2023 kern.info kernel: [ 94.810275] br-lan: port 1(eth0.1) entered blocking state
Sat Dec 16 20:32:11 2023 kern.info kernel: [ 94.815863] br-lan: port 1(eth0.1) entered disabled state
Sat Dec 16 20:32:11 2023 kern.info kernel: [ 94.821775] device eth0.1 entered promiscuous mode
Sat Dec 16 20:32:11 2023 kern.info kernel: [ 94.881201] br-lan: port 1(eth0.1) entered blocking state
Sat Dec 16 20:32:11 2023 kern.info kernel: [ 94.886791] br-lan: port 1(eth0.1) entered forwarding state
Sat Dec 16 20:32:11 2023 daemon.notice netifd: Interface ‘lan’ is enabled
Sat Dec 16 20:32:11 2023 daemon.notice netifd: Interface ‘lan’ is setting up now
Sat Dec 16 20:32:11 2023 daemon.info avahi-daemon[4572]: Joining mDNS multicast group on interface br-lan.IPv4 with address 192.168.20.1.
Sat Dec 16 20:32:11 2023 daemon.info avahi-daemon[4572]: New relevant interface br-lan.IPv4 for mDNS.
Sat Dec 16 20:32:11 2023 daemon.info avahi-daemon[4572]: Registering new address record for 192.168.20.1 on br-lan.IPv4.
Sat Dec 16 20:32:11 2023 daemon.notice netifd: Interface ‘lan’ is now up
Sat Dec 16 20:32:11 2023 daemon.notice netifd: bridge ‘br-lan’ link is up
Sat Dec 16 20:32:11 2023 daemon.notice netifd: Interface ‘lan’ has link connectivity
Sat Dec 16 20:32:11 2023 daemon.notice netifd: VLAN ‘eth0.1’ link is up
Sat Dec 16 20:32:11 2023 daemon.info avahi-daemon[4572]: Joining mDNS multicast group on interface lo.IPv4 with address 127.0.0.1.
Sat Dec 16 20:32:11 2023 daemon.info avahi-daemon[4572]: New relevant interface lo.IPv4 for mDNS.
Sat Dec 16 20:32:11 2023 daemon.info avahi-daemon[4572]: Registering new address record for 127.0.0.1 on lo.IPv4.
Sat Dec 16 20:32:11 2023 daemon.info avahi-daemon[4572]: Joining mDNS multicast group on interface lo.IPv6 with address ::1.
Sat Dec 16 20:32:11 2023 daemon.info avahi-daemon[4572]: New relevant interface lo.IPv6 for mDNS.
Sat Dec 16 20:32:11 2023 daemon.info avahi-daemon[4572]: Registering new address record for ::1 on lo..
Sat Dec 16 20:32:12 2023 daemon.notice netifd: Interface ‘loopback’ is enabled
Sat Dec 16 20:32:12 2023 daemon.notice netifd: Interface ‘loopback’ is setting up now
Sat Dec 16 20:32:12 2023 daemon.notice netifd: Interface ‘loopback’ is now up
Sat Dec 16 20:32:12 2023 daemon.notice netifd: Interface ‘tethering’ is enabled
Sat Dec 16 20:32:12 2023 daemon.notice netifd: Interface ‘wan’ is enabled
Sat Dec 16 20:32:12 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:12 2023 daemon.notice netifd: Network device ‘eth0’ link is up
Sat Dec 16 20:32:12 2023 daemon.notice netifd: Network device ‘lo’ link is up
Sat Dec 16 20:32:12 2023 daemon.notice netifd: Interface ‘loopback’ has link connectivity
Sat Dec 16 20:32:12 2023 daemon.notice netifd: Network device ‘eth1’ link is up
Sat Dec 16 20:32:12 2023 daemon.notice netifd: Interface ‘tethering’ has link connectivity
Sat Dec 16 20:32:12 2023 daemon.notice netifd: Interface ‘tethering’ is setting up now
Sat Dec 16 20:32:12 2023 daemon.notice netifd: VLAN ‘eth0.2’ link is up
Sat Dec 16 20:32:12 2023 daemon.notice netifd: Interface ‘wan’ has link connectivity
Sat Dec 16 20:32:12 2023 daemon.notice netifd: Interface ‘wan’ is setting up now
Sat Dec 16 20:32:13 2023 daemon.info avahi-daemon[4572]: Joining mDNS multicast group on interface eth0.IPv6 with address fe80::9683:c4ff:fe0c:d7eb.
Sat Dec 16 20:32:13 2023 daemon.info avahi-daemon[4572]: New relevant interface eth0.IPv6 for mDNS.
Sat Dec 16 20:32:13 2023 daemon.info avahi-daemon[4572]: Registering new address record for fe80::9683:c4ff:fe0c:d7eb on eth0.
Sat Dec 16 20:32:13 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:13 2023 daemon.notice netifd: wan (5274): udhcpc: started, v1.35.0
Sat Dec 16 20:32:13 2023 daemon.notice netifd: tethering (5272): udhcpc: started, v1.35.0
Sat Dec 16 20:32:13 2023 daemon.info avahi-daemon[4572]: Joining mDNS multicast group on interface eth1.IPv6 with address fe80::e5b:8fff:fe27:9a64.
Sat Dec 16 20:32:13 2023 daemon.info avahi-daemon[4572]: New relevant interface eth1.IPv6 for mDNS.
Sat Dec 16 20:32:13 2023 daemon.info avahi-daemon[4572]: Registering new address record for fe80::e5b:8fff:fe27:9a64 on eth1..
Sat Dec 16 20:32:14 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:15 2023 daemon.notice netifd: wan (5274): udhcpc: broadcasting discover
Sat Dec 16 20:32:15 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:15 2023 daemon.notice netifd: tethering (5272): udhcpc: broadcasting discover
Sat Dec 16 20:32:15 2023 daemon.notice netifd: tethering (5272): udhcpc: broadcasting select for 192.168.8.100, server 192.168.8.1
Sat Dec 16 20:32:15 2023 daemon.notice netifd: tethering (5272): udhcpc: lease of 192.168.8.100 obtained from 192.168.8.1, lease time 86400
Sat Dec 16 20:32:15 2023 user.notice mwan3[5164]: Using firewall mask 0x3F00
Sat Dec 16 20:32:15 2023 user.notice mwan3[5164]: Max interface count is 60
Sat Dec 16 20:32:16 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:16 2023 daemon.notice netifd: radio1 (5184): sh: acs_survey: out of range
Sat Dec 16 20:32:17 2023 daemon.info avahi-daemon[4572]: Joining mDNS multicast group on interface eth1.IPv4 with address 192.168.8.100.
Sat Dec 16 20:32:17 2023 daemon.info avahi-daemon[4572]: New relevant interface eth1.IPv4 for mDNS.
Sat Dec 16 20:32:17 2023 daemon.info avahi-daemon[4572]: Registering new address record for 192.168.8.100 on eth1.IPv4.
Sat Dec 16 20:32:17 2023 daemon.notice netifd: Interface ‘tethering’ is now up
Sat Dec 16 20:32:17 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:17 2023 daemon.notice netifd: Wireless device ‘radio0’ is now up
Sat Dec 16 20:32:18 2023 daemon.notice netifd: wan (5274): udhcpc: broadcasting discover
Sat Dec 16 20:32:18 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:18 2023 daemon.notice procd: /etc/rc.d/S96led: setting up led WLAN2G
Sat Dec 16 20:32:19 2023 daemon.notice procd: /etc/rc.d/S96led: setting up led WLAN5G
Sat Dec 16 20:32:19 2023 daemon.notice hostapd: Configuration file: /var/run/hostapd-phy1.conf (phy wlan0) → new PHY
Sat Dec 16 20:32:19 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:19 2023 user.notice mwan3[5164]: Execute ifup event on interface lan (br-lan)
Sat Dec 16 20:32:19 2023 kern.info kernel: [ 102.567477] br-lan: port 2(wlan0) entered blocking state
Sat Dec 16 20:32:19 2023 kern.info kernel: [ 102.573023] br-lan: port 2(wlan0) entered disabled state
Sat Dec 16 20:32:19 2023 kern.info kernel: [ 102.578852] device wlan0 entered promiscuous mode
Sat Dec 16 20:32:19 2023 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Sat Dec 16 20:32:19 2023 daemon.notice hostapd: ACS: Automatic channel selection started, this may take a bit
Sat Dec 16 20:32:19 2023 daemon.notice hostapd: wlan0: interface state COUNTRY_UPDATE->ACS
Sat Dec 16 20:32:19 2023 daemon.notice hostapd: wlan0: ACS-STARTED
Sat Dec 16 20:32:20 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:20 2023 daemon.info dnsmasq[1]: exiting on receipt of SIGTERM
Sat Dec 16 20:32:20 2023 daemon.info dnsmasq[1]: started, version 2.86 cachesize 150
Sat Dec 16 20:32:20 2023 daemon.info dnsmasq[1]: DNS service limited to local subnets
Sat Dec 16 20:32:20 2023 daemon.info dnsmasq[1]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP conntrack ipset auth cryptohash DNSSEC no-ID loop-detect inotify dumpfile
Sat Dec 16 20:32:20 2023 daemon.info dnsmasq[1]: UBus support enabled: connected to system bus
Sat Dec 16 20:32:20 2023 daemon.info dnsmasq-dhcp[1]: DHCP, IP range 192.168.20.100 – 192.168.20.249, lease time 12h
Sat Dec 16 20:32:20 2023 daemon.info dnsmasq[1]: using nameserver 52.29.2.17#53
Sat Dec 16 20:32:20 2023 daemon.info dnsmasq[1]: using nameserver 3.10.65.124#53
Sat Dec 16 20:32:20 2023 daemon.info dnsmasq[1]: using only locally-known addresses for test
Sat Dec 16 20:32:20 2023 daemon.info dnsmasq[1]: using only locally-known addresses for onion
Sat Dec 16 20:32:20 2023 daemon.info dnsmasq[1]: using only locally-known addresses for localhost
Sat Dec 16 20:32:20 2023 daemon.info dnsmasq[1]: using only locally-known addresses for invalid
Sat Dec 16 20:32:20 2023 daemon.info dnsmasq[1]: using only locally-known addresses for bind
Sat Dec 16 20:32:20 2023 daemon.info dnsmasq[1]: using only locally-known addresses for lan
Sat Dec 16 20:32:20 2023 daemon.info dnsmasq[1]: read /etc/hosts - 4 addresses
Sat Dec 16 20:32:20 2023 daemon.info dnsmasq[1]: read /tmp/hosts/dhcp.cfg01411c - 3 addresses
Sat Dec 16 20:32:20 2023 daemon.info dnsmasq-dhcp[1]: read /etc/ethers - 0 addresses
Sat Dec 16 20:32:21 2023 daemon.notice netifd: wan (5274): udhcpc: broadcasting discover
Sat Dec 16 20:32:21 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:21 2023 daemon.notice netifd: Wireless device ‘radio1’ is now up
Sat Dec 16 20:32:22 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:23 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:24 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:25 2023 daemon.info samba4-server: io_uring module found, enabling VFS io_uring. (also needs Kernel 5.4+ Support)
Sat Dec 16 20:32:25 2023 user.notice mwan3[5164]: Starting tracker on interface lan (br-lan)
Sat Dec 16 20:32:25 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:26 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:26 2023 daemon.notice hostapd: wlan0: ACS-COMPLETED freq=2437 channel=6
Sat Dec 16 20:32:26 2023 daemon.notice hostapd: wlan0: interface state ACS->HT_SCAN
Sat Dec 16 20:32:27 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:27 2023 daemon.notice hostapd: 20/40 MHz operation not permitted on channel pri=6 sec=10 based on overlapping BSSes
Sat Dec 16 20:32:27 2023 daemon.notice hostapd: Fallback to 20 MHz
Sat Dec 16 20:32:28 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:28 2023 daemon.notice netifd: Network device ‘wlan0’ link is up
Sat Dec 16 20:32:28 2023 kern.info kernel: [ 111.544626] br-lan: port 2(wlan0) entered blocking state
Sat Dec 16 20:32:28 2023 kern.info kernel: [ 111.550191] br-lan: port 2(wlan0) entered forwarding state
Sat Dec 16 20:32:29 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:30 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:30 2023 daemon.notice procd: /etc/rc.d/S99disk_manage: start app = /usr/bin/disk_manage
Sat Dec 16 20:32:31 2023 daemon.err lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:368) Wait phy ready…
Sat Dec 16 20:32:31 2023 daemon.notice hostapd: wlan0: interface state HT_SCAN->ENABLED
Sat Dec 16 20:32:31 2023 daemon.notice hostapd: wlan0: AP-ENABLED
Sat Dec 16 20:32:32 2023 daemon.info lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:412) found device: radio0 mac80211 phy0 5g
Sat Dec 16 20:32:32 2023 daemon.info lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:412) found device: radio1 mac80211 phy1 2g
Sat Dec 16 20:32:33 2023 daemon.info lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:1483) new scan task…
Sat Dec 16 20:32:33 2023 daemon.info lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:1495) Scan starting…
Sat Dec 16 20:32:36 2023 kern.err kernel: [ 118.442522] ath10k_pci 0000:00:00.0: failed to read device EEPROM at 0000
Sat Dec 16 20:32:36 2023 kern.warn kernel: [ 118.449579] ath10k_pci 0000:00:00.0: failed to read calibration data from EEPROM: -22
Sat Dec 16 20:32:37 2023 daemon.err usbmuxd[6644]: [20:32:37.787][3] usbmuxd v1.1.1 starting up
Sat Dec 16 20:32:37 2023 daemon.err usbmuxd[6644]: [20:32:37.833][3] Using libusb 1.0.24
Sat Dec 16 20:32:37 2023 daemon.err usbmuxd[6644]: [20:32:37.841][3] Initialization complete
Sat Dec 16 20:32:37 2023 daemon.err usbmuxd[6644]: [20:32:37.851][3] Enabled exit on SIGUSR1 if no devices are attached. Start a new instance with “–exit” to trigger.
Sat Dec 16 20:45:04 2023 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Sat Dec 16 20:45:04 2023 daemon.notice procd: /etc/rc.d/S99gl_nas_sys: 6333 root 27280 R /usr/sbin/smbd -F
Sat Dec 16 20:45:05 2023 daemon.notice procd: /etc/rc.d/S99gl_nas_sys_dl: start app = /usr/bin/gl_nas_sys
Sat Dec 16 20:45:05 2023 daemon.notice procd: /etc/rc.d/S99gl_nas_sys_dl: === nas enable
Sat Dec 16 20:45:06 2023 daemon.notice procd: /etc/rc.d/S99gl_nas_sys_up: start app = /usr/bin/gl_nas_sys
Sat Dec 16 20:45:07 2023 daemon.notice procd: /etc/rc.d/S99gl_nas_sys_up: === nas enable
Sat Dec 16 20:45:07 2023 kern.warn kernel: [ 126.210006] ath10k_pci 0000:00:00.0: pdev param 0 not supported by firmware
Sat Dec 16 20:45:07 2023 daemon.info lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:1637) .tmp.phy0.sta0: scan…
Sat Dec 16 20:45:09 2023 daemon.notice procd: /etc/rc.d/S99nfsd: exportfs: /etc/exports [1]: Neither ‘subtree_check’ or ‘no_subtree_check’ specified for export "
:/mnt".
Sat Dec 16 20:45:09 2023 daemon.notice procd: /etc/rc.d/S99nfsd: Assuming default behaviour (‘no_subtree_check’).
Sat Dec 16 20:45:09 2023 daemon.notice procd: /etc/rc.d/S99nfsd: NOTE: this default has changed since nfs-utils version 1.0.x
Sat Dec 16 20:45:09 2023 daemon.notice procd: /etc/rc.d/S99nfsd: exportfs: /mnt does not support NFS export
Sat Dec 16 20:45:11 2023 kern.warn kernel: [ 130.033490] NFSD: Using /var/lib/nfs/v4recovery as the NFSv4 state recovery directory
Sat Dec 16 20:45:11 2023 kern.warn kernel: [ 130.041734] NFSD: Using legacy client tracking operations.
Sat Dec 16 20:45:11 2023 kern.info kernel: [ 130.047514] NFSD: starting 10-second grace period (net f0000029)
Sat Dec 16 20:45:11 2023 daemon.debug eco: (gl-cloud:694) lua-eco version: 2.5.1
Sat Dec 16 20:45:12 2023 daemon.notice rpc.statd[7281]: Version 2.5.4 starting
Sat Dec 16 20:45:12 2023 daemon.warn rpc.statd[7281]: Flags: No-Daemon TI-RPC
Sat Dec 16 20:45:13 2023 daemon.notice rpc.mountd[7282]: Version 2.5.4 starting
Sat Dec 16 20:45:13 2023 daemon.notice rpc.statd[7281]: Initializing NSM state
Sat Dec 16 20:45:13 2023 daemon.warn rpc.statd[7281]: Running as root. chown /var/lib/nfs to choose different user
Sat Dec 16 20:45:15 2023 daemon.notice procd: /etc/rc.d/S99webdav_ser: start app = /usr/bin/webdav_ser
Sat Dec 16 20:45:15 2023 daemon.info procd: - init complete -
Sat Dec 16 20:45:17 2023 daemon.info lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:1675) .tmp.phy0.sta0: found 1 networks
Sat Dec 16 20:45:17 2023 daemon.info lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:1538) scan finished
Sat Dec 16 20:45:19 2023 daemon.err eco: (gl-cloud:248) fetch server fail: connect fail: handshake timeout
Sat Dec 16 20:45:19 2023 daemon.err eco: (gl-cloud:519) reconnect mqtt in 5s…
Sat Dec 16 20:45:19 2023 daemon.info lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:897) Switching…
Sat Dec 16 20:45:19 2023 daemon.info lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:1360) prepare connect ‘Wolfistein5GHz(B0:F2:08:96:44:1A)’, WPA2 PSK (CCMP) channel 36
Sat Dec 16 20:45:19 2023 daemon.info lua: (…07/ipkg-mips_24kc/gl-sdk4-repeater/usr/sbin/repeater:1458) connecting ‘Wolfistein5GHz B0:F2:08:96:44:1A’…
Sat Dec 16 20:45:20 2023 daemon.notice netifd: Wireless device ‘radio0’ is now down
My AR750S crashes randomly. No crash-logfile. I dont know why this happens…
Does it crash if you stream via cable, not wifi?
Can you also try another better power adapter?
Thanks for the hint with the power adaptor. After removing the Huawai E3372 “SIM-Card-USB-Modem”, everything works fine at the moment. Maybe the E3327 needs to much power or it is not really compatible.
EDIT: It crashed again. Without the E3372. I ll try another power adaptor.
I bought a new power adaptor with 18w. But the router randomly disconnects from wlan, randomly reboots, …
I think its time to throw it into the garbage. Maybe a hardware defect.
logread.zip (28.3 KB)
So the crash is with USB connected (and exroot)?
AR750s is not powerful to support USB desk stably.
No. The USB Port is empty. I use an SD-Card for file storage.
And again: Complete reset, install samba, ~10min streaming → suddenly crash
logread.zip (26.6 KB)
Downgraded to 3.126 and everything works fine. 4.3.7 seems to be incompatible with the ar7502 and the samba tools.
Could be an RAM issue since there isn’t much memory and samba needs a lot of it when transferring big files.
