I need Trojan support on GL-MT300N-V2 . Can anyone help provide ipk file to install? Thanks!
How do you want the Trojan work?
Both shadowsocks plus and passall can support trojan. But shadowsocks plus in lastest version of Gl-inet image can’t support it. There also have no passall app in the release. Could you help integrate it?
Trojan is best VPN protocol currently.
Does this mean if we upgrade shadowsocks then it should be supported?
Yes, pls help upgrade to latest version shadowsocks plus and release the image. It’s better also to include service “passall”.
Thanks very much!
