When “AdGuard Home Handle Client Requests” is enabled, it prevents docker from updating.
I get the following error when trying to update the docker containers:
Error response from daemon: Head “https://registry-1.docker.io/v2/containrrr/watchtower/manifests/latest”: Get “https://auth.docker.io/token?scope=repository%3Acontainrrr%2Fwatchtower%3Apull&service=registry.docker.io”: dial tcp: lookup auth.docker.io on 10.5.0.1:53: read udp 10.5.0.6:59815->10.5.0.1:53: i/o timeout
Disabling the new feature fixes docker updating. Could you guys test on your end? From the error it looks like udp is failing, but not sure. Maybe an extra firewall rule is required.
