but the 4.7.0-op24 gives me 'only' 430 Mbps, vs. 734 Mbps (4.7.0 Stable) on Speedtest.net download. So I went back to the 'half functional' 4.7.0 stable, and hope someone can help me trying to get the GL GUI back
Hello
I update from 4.6.8 op21 to the latest 4.7.0-op21 stable yesterday, without wiping settings.
All seems to be working fine.
The only thing I had to fixed, is the Argon Theme I had to reinstall otherwise I get those errors:
After I reinstall the ipk for the argon theme, no more errors ![]()
I have just updated to the main line 4.7.0 firmware on my MT6000 and all appears to be working apart from an issue with the wifi.
So I have 5G guest mode as my only wifi connection.
I noticed that when the SSID is hidden and I connect my primary phone (OnePlus 10pro) that it will work but when I connect another device (old phone) and if I disconnect my primary phone, I then can't see my SSID.
I then have to reboot the router or change the SSID to non hidden to get my primary phone to connect to the 5G guest wifi again.
Though, my old phone can still connect fine to the wifi. Hidden or not hidden.
Happy to PM logs upon request.
Edit: Also, one other bug is that the time zone keeps defaulting to "Atlantic/Reykjavik".
Just reporting in that my Brume 2 refuses to upgrade to 4.7.0
Tried app update
Tried web update
Tried local update
Anyone got any ideas as this is ridiculous.
If GL wants access it's on Goodcloud
You will need to share much more detail than this.
Without knowing the error message, log, screenshot, will be impossible to understand the issue
Click on "Install now" and wait. It will take a while to install.
The 2nd option is accessing via browser and updating it via Admin Panel
Neither works
Not does local update
Just reboots the mt2500 back to 4.6.8
This issue sound incredible strange, hopefully they find a solution, maybe you can try to read the console output via uart/serial? (Opening might void warrenty i guess).
Can't install Openwrt either.
Just rebooted straight to 4.6.8
Does it do that also via luci sys upgrade?
Yes via Luci or ssh shell, both fail and I get rebooted to 4.6.8.
Something's broken here.
Message in ssh is cannot parse fw_env.config
fw_env.config is used by uboot settings, fw_printenv shows nothing, uboot-envtools are installed by default by GL in stock firmware
and if you install fdisk, what is the output of fdisk -l ?
Also to be sure you dont use any external storage?
No external storage
root@GL-MT2500:~# fdisk -l
Disk /dev/mmcblk0: 7.28 GiB, 7818182656 bytes, 15269888 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: 2BD17853-102B-4500-AA1A-8A21D4D7984D
Device Start End Sectors Size Type
/dev/mmcblk0p1 4096 8191 4096 2M Linux filesyste
/dev/mmcblk0p2 8192 9215 1024 512K Linux filesyste
/dev/mmcblk0p3 9216 13311 4096 2M Linux filesyste
/dev/mmcblk0p4 13312 17407 4096 2M Linux filesyste
/dev/mmcblk0p5 17408 82943 65536 32M Linux filesyste
/dev/mmcblk0p6 82944 15269887 15186944 7.2G Linux filesyste
Disk /dev/mtdblock0: 2 MiB, 2097152 bytes, 4096 sectors
Thanks, i gonna tag @bruce i think he can help more ![]()
It's on Goodcloud, can share to GL staff if needed.
- Did you try update it on the uboot mode?
- try swapping other power supply?
- If above does not work, please contact my colleagues support@gl-inet.com to further check with us.
Can you DM me the link to this ad testing site?
Edit, nvm, I found it. With AGH running on the x2000, I get 96%
I saw the 4.7 popup and just upgraded my Flint 2 (from previous version). However it seems the router is going through a reboot loop. Removed power supply and connected and same issue ![]()
yeah looks like it is bricked... I'll try to uboot
