First of all, the AR-750 is just about everything I’ve been looking for in a portable router. I would like to know about a few things.
- I understand that the firmware is a customized branch of OpenWRT. Are there advantages or disadvantages to changing to pure OpenWRT?
- Is it possible to map the physical switch on the router to do a different function of choosing? I would like it to enable/disable the DHCP server. There are times when I just want the router to act as an AP, and while using it in router mode doesn’t change that, disabling DHCP and only using the LAN ports (and not the WAN port) is close for a lot of scenarios. Also, to extend that switch function, it could disable DHCP and ALSO move the WAN Ethernet port over to the LAN (internal) VLAN so that there are 3 switch ports.
Thanks!
