I installed the nextdns-cli client for openwrt but at every restart of the router I lose the settings
Do you have the same problem?
Which router are you using?
In our router and stock firmware, you cannot use Nexdns, right? It needs a newer ssl library.
E750 and AR750S
I use this →
Installation:
1- ssh openwrt console
2- OpenWRT · nextdns/nextdns Wiki · GitHub
Can you check ?
Hope when you guys have Adguard Home ready then it will be easy to use NextDNS
@reflector opkg install luci-app-adblock
opkg install luci-app-dnsoverhttps
And all is good, these packages can either be added manually (look at downloads.openwrt.org/yourversion/feeds) but if you haven’t got an far too old firmware installed anyways, in the gl-stock firmwares via LuCi / SSH are they to get without problems as well.
