i bought the GL.iNet GL-AR300M-Ext which was running on an older firmware, when i updated the firmware there is no enable vpn button or a force vpn like there was before. has this setting been moved elsewhere in the settings?
By default, it is “force vpn” now.
so there is no way of disabling the vpn?what if i just want to use the network as is.
You can just simply click “disconnect” for your vpn!
