i have three devices:
GL-B1300 / GL-AR150 / GL-AR300M
With all the devies i do the same,
i am use the devices behind a router. (Bridge Mode)
i have nothing special configurated,
only the dns-setting, nothing more.
I am using dhcp.
All the device have a new public ip-adress.
Only the GL-B1300 works fine.
The GL-AR150 / GL-AR300M have no internet connection.
I will to try explain my setup for the GL-B1300.
Yes, i have a main router (“Fritz Box 6490 Cable”), yes an this cable router has a public ip from my ISP.
The “Fritz Box 6490 Cable” has 4 lan Ports.
Now i am configure one lan port in bridge mode.
“In bridge mode, the cable router acts as a simple cable modem,”
Now i am connect the GL-B1300 with this lan port.
From the lan port (fritz Box) in the wan port GL-B1300.
I connect my win10 notebook with wifi or cable with the GL-B1300.
All works fine.
The only things i have configured is dns.
Nothing more.
I have access to the internet.
When look at GL-B1300 (http://192.168.8.1) i see i am connect with dchp
and i have ip-adress that is not in my local range.
When i am looking at “https://www.whatismyip.com/” i see i have a ip adress from my ISP.
I see the ip-adress and the host is my ISP.
The ip-adress is a another when i am directly connect to my Fritz Box.
You say: “The bridged devices will not be able to have public IP.”,
but what for a ip-adress i have them ?,
when it is not public, and is not from my ISP.
Now i do the same with the “GL-AR150 / GL-AR300M” but i have no connect to the internet.
I saw i am connect with dhcp/cable and i have a new ip-adress (not local range),
but no connect to the internet.
Must i use the “GL-AR150 / GL-AR300M” i one special mode ?
I have left the “Switch Button Configuration” in default, is that the problem ?.
Or what is going here ?
That i have excatly done.
Thats works with the “GL-B1300”
with “GL-AR150 / GL-AR300M” no.
I have try this, “with” dns-setting, and without dns-entries.
But ervertime the same result.
when i go to the luci-diagnotis, and try the actions (ping, …), is no working.
