Mine tries to connect forever but never does. Tried many different servers with 3 different firmware. Attached images show log of latest attempt with 4.02 beta firmware.
Has anyone had success with this?
try extracting your keys using this tutorial:
connect using nord client
and then:
wg showconf wg0 > wg.conf
Import that file into A1300, and you are good to go!
I was extracting the server public key incorrectly (using nordvpn status instead of wg showconf). So my config files were incorrect. This caused the router to hang while attempting to connect to the server. Thank you anterus
