Does anyone know how to compile openvpn for the GL.iNet GL-SFT1200 (Opal) ? Is there a sdk toolkit? If it’s possible, we just need to apply the xor patch to the openvpn sources and compile it.
We are testing the AmneziaWG obfuscation protocol on MT3000, which supports obfuscation parameters on VPN client and VPN server. You can use one MT3000 as the obfuscation server and the other MT3000 as the obfuscation client.
Please upgrade to v4.8.2 (beta) firmware for MT3000
The current GL firmware of SFT1200 already supports the standard OpenVPN program.
May I know why you need to compile OpenVPN yourself?
In order to apply the xor patch to support the scramble of the openvpn protocol
I PMed to you with the SFT1200 SDK.
thank you.
