Hello
I just saw a new function called “One Click Channel Optimisation” in release note of Convexa-B 3.104. However I could not find where is this function. My device is in Mesh mode. Thank you.
Sincerely
Max Fu
Hello
Sincerely
Max Fu
In Mesh mode, the channel is locked so you cannot change it.
What you can do is run the channel optimisation on the master node BEFORE you setup your mesh.
It will then lock the mesh to the optimised channels.
Seemed to optimise on the same channels I was going to choose based on my wifi scanning anyway.
