I’ve set up privoxy 3.0.24-1 on my VELICA router with OpenWrt (15.05).
The proxy is running and listening on port 8118.
I would like to filter url from my wireguard interface. I am you not using explicit proxy configuration (in the browser) but transparent redirect via iptables rules to redirect port 80 and 443 to 8118
iptables -t nat -A PREROUTING -i wg0 -p tcp --dport 443 -j REDIRECT --to-port 8118
iptables -t nat -A PREROUTING -i wg0 -p tcp --dport 80 -j REDIRECT --to-port 8118
I tried setting a example of blocking by only allowing 2 domains in a block rule:
{ -block}
.netflix.com
.disney.com
This rule can be found under the file user.action, which I include in my config in /etc/config/privoxy. Both options ‘toggle’ and ‘enforce_blocks’ are set to 1. However, I do not see any filtered url from wireguard connections, the proxy doesn’t block anything…
Any idea on that matter?
Is this something that can be achieved? And how?
