OP25 Firmware for Flint 2 & Beryl AX is out
I posted some news in the CVE thread and answered that question there. :slight_smile:
Status update:
  • Router uptime: 22 hours so far.
  • Streaming movies, using the internet all day, and doing speed tests has all worked perfectly.
  • There has not been a single drop of the internet connection at all. My script (from the linked post I am replying to) checks connectivity every 4 seconds:
[2026-11-03 07:29:10] [INFO] Monitoring started...
[2026-11-03 07:29:10] [INFO] Initial state: ONLINE
Absolutely rock solid. Still online. No freezes at all.
Looking good so far. I'll keep running this monitoring script to ensure it stays this way.
I hope people who test the other stuff that I'm not testing (AdGuard Home, VPN, etc) also have their crashes resolved in this update.
Just updated my GL-MT3000 to v4.11.0-op25 (Keep Settings enabled). Everything works fine, DNS, WireGuard, Wi-Fi, Tailscale, Ethernet, VLAN, except the Repeater settings which is probably corrupted, likely from keep settings enabled. Mesh isn’t in this firmware, unlike the op21 firmware. Other than that, no issues found in my end.
For those that just made the jump:
How is wifi in this latest op25 version compared op21 version on the Flint 2?
Most overall throughput on both bands and signal strength/stability on 2.4 GHz
I had tried op24 before but my far away 2.4 GHz devices struggled - likely because beamforming on the proprietary/closed source drivers in op21 are more tuned to the exact antenna geometry or amps etc... of the router...
I don't use op21 since op24 came out years ago but my wifi signal is working fine and still reaching my most afar IOT devices :call_me_hand:
@geobernd Your question is way too specific to your setup and won't get any meaningful replies that help you. The only way is to install the latest op25 (and do a settings reset to ensure nothing is broken).
Throughput is 100% dependent on every person's personal home and neighbor WiFi interference. Especially on the 2.4 GHz band.
Device connectivity and speeds are 100% dependent on your devices (not the router). The limiting factor is how "quiet" your devices are, which limits their bandwidth, loses packets, loses connection, etc. This in turn makes your DEVICES negotiate a slower speed with the router, "talk slower... I can't hear you..." basically.
For my own home in a residential apartment building, 2.4 and 5 GHz has 100% connection reliability and reaches all devices and has slightly better speeds than the old "stable" ancient build from 2019 that they barely keep alive by adding GL-iNet features on top of. I will never go back to "stable".
The "op25" is the best and most-updated the router has ever been.
Status update:
  • Router uptime: 1 day 10 hours
  • There hasn't been any connection loss or freeze or slowdown.
Updated yesterday. All stable by now. Best regards
Installed 4.11.0-op25 yesterday.
Today the wifi died suddenly, never happened before.
I had to reboot the router for it to wake up. I have vanilla setup, with adguard and tailscale thats it. Normal amount of wireless devices. This cannot be related to anything than the new firmware.
Has this release fixed the security vulnerability tracked as CVE-2026-98432 ?
@MilesTEG @978rhvbn_L
Mesh is not currently supported on the OP firmware. We may assess the feasibility of adding support after completing our Mesh work on other models with closed-source firmware. Thank you for your feedback.
@Lastimosa @Chimpans @dnz
We have started working on a fix for CVE-2026-98432 and are validating it. The fix will be included in the next release.
@oag
Thanks for reporting the Wi-Fi issue. Do you have any logs from around the time it happened that you could share with us via a private message?
How to export logs:
How to send private messages:
Adguard Home DNS + VPN/Tailscale were known to cause issues in the previous firmware too, so it seems that's still a problem. I do not use either of those and have 100% uptime of the WiFi (my monitoring tool still runs, and there's not a single drop!).
Thanks a lot for that. Sounds like you will backport the kernel patch to your routers? If so, I applaud you! That's the right way to protect all of your older releases too.
And upstream OpenWrt 25 will officially update in the coming days/weeks with a fix too (they will include the 6.12.113 kernel which is fixed).
Hello @will.qiu
You mean not yet supported for Flint2 on OP25 , right ? Because the Flint4 as an op25 with Mesh suppport.
Do you recommend to wait for an op25 mesh ready firmware ? Ou should I install the 4.11 with the old OpenWRT version ?
Thanks for your answer :innocent:
:handshake: sent the logs I had
Status update:
  • Flint 2 on v4.11.0-op25
  • Router uptime: 3 days 20 hours
  • Internet drops/freezes (WiFi, checked every 4 seconds since the router started): ZERO
  • Internet slowdowns: ZERO
Same here: 3 days 22 hours uptime with no problem. Router Flint 2.
Updated from 4.9.1 OP25 with keeping settings.
So if you have vanilla openwrt installed don't you on the wrong forums? :thinking:
Hey, im on latest op25 firmware too. So far so good.
At first i had problems because ipv6 ula prefix was changing to default every time but now it stays what i entered.
I have very much entries of this error reporting in my logs, like every 20 seconds and i dont know what it is:
Sun Nov  8 21:28:09 2026 kern.warn kernel: [188651.175535] nfnetlink_queue: dst lost after hook pf=2 hook=2 index=6 priority=0 fn=nft_data_dump [nf_tables] in=br-guest out=pppoe-wan mark=0x0
Sone ideas ?
Just an update, my Flint2 (it's a beast) with 4.11.0-op25 with a "keep settings" upgrade from 4.9.1-op25 on a new location (as always centered to the floor plan and above the floor about 6 feet) it's doing great, even the spectrum it's way more crowded on the new location the Flint2 it's doing amazing :raising_hands:
Just saying...... :call_me_hand:
