Opal GL-SFT1200 wireguard client connect error rekey timeout
Hello, I want to work remotely more often, but I want to keep my home IP address so that my work laptop will still work.
So I bought two Opal routers. One is to be located at my main router in Germany and connected via cable or WiFi. I take the other Opal router with me when I travel.Of course, I wanted to test and set everything up beforehand, which I did, but unfortunately I'm stuck and have a few errors.
I don't know if I'm making a mistake with router A or if I have one with router B. Everything should run via Wireguard. Also read many topics here in the forum, with no chance.
Here is my setup:
On my Main Router „PortFowarding“ is active to Port 51820
I did it like in this tutorial: https://www.youtube.com/watch?v=LXbDg1v65Qs
-Router A (Opal GL-SFT1200) connected to my main router via wifi / also tried via cable
-DNNS is enabled
-Firmware: 4.3.28 release2
-Profiles Router A
[Interface]
Address = 10.0.0.2/24
PrivateKey = xxxxx
DNS = xx.x.xx.x
MTU = xxxx
[Peer]
AllowedIPs = 0.0.0.0/0,::/0
Endpoint = xxxxxxx.glddns.com:51820
PersistentKeepalive = 25
PublicKey = xxxxxxxx
When I start the VPN Server via WireGuard, I get this messages:
The Pages shows me „The WireGuard server is currently ON“
These are the Logs:
Sat Oct 18 22:02:09 2025 daemon.notice netifd: Interface 'wgserver' is setting up now
Sat Oct 18 22:02:10 2025 kern.info kernel: [10497.467210] IPv6: ADDRCONF(NETDEV_UP): wgserver: link is not ready
Sat Oct 18 22:02:10 2025 daemon.notice netifd: Interface 'wgserver' is now up
Sat Oct 18 22:02:10 2025 daemon.notice netifd: Network device 'wgserver' link is up
Sat Oct 18 22:02:11 2025 user.notice mwan3[31653]: Execute ifup event on interface wgserver (wgserver)
Sat Oct 18 22:02:12 2025 user.notice mwan3[31653]: Starting tracker on interface wgserver (wgserver)
Sat Oct 18 22:02:15 2025 user.notice firewall: Reloading firewall due to ifup of wgserver (wgserver)
Sat Oct 18 22:02:16 2025 user.notice relay: Reloading relay due to ifup of wgserver (wgserver)
This is the Log I get from the System
Sat Oct 18 22:02:15 2025 user.info mwan3rtmon[2502]: Detect rtchange event.
Sat Oct 18 22:02:17 2025 authpriv.notice sudo: root : TTY=unknown ; PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/gl_ddns/dynamic_dns_updater.sh -- stop
Sat Oct 18 22:02:18 2025 user.notice ddns-scripts[26645]: glddns: PID '26645' terminated by 'SIGTERM' at 2025-10-18 22:02
Sat Oct 18 22:02:19 2025 authpriv.notice sudo: root : TTY=unknown ; PWD=/ ; USER=root ; GROUP=nonevpn ; COMMAND=/usr/lib/gl_ddns/dynamic_dns_updater.sh -- start
Sat Oct 18 22:02:20 2025 user.notice ddns-scripts[32530]: ddns: PID '32530' started at 2025-10-18 22:02
Sat Oct 18 22:02:20 2025 user.warn ddns-scripts[32530]: ddns: Service section disabled! - TERMINATE
Sat Oct 18 22:02:20 2025 user.notice ddns-scripts[32533]: glddns: PID '32533' started at 2025-10-18 22:02
Sat Oct 18 22:02:20 2025 user.warn ddns-scripts[32530]: ddns: PID '32530' exit WITH ERROR '1' at 2025-10-18 22:02
Sat Oct 18 22:02:21 2025 user.warn ddns-scripts[32533]: glddns: NO valid IP found
Is here already the error ? Or is everything fine ??
Router B (Opal GL-SFT1200) connected to a hotspot to my iphone (so not my main wifi)
-When I start the CPN Client WireGuard I get this messages in the Logs:
Sat Oct 18 22:06:21 2025 daemon.notice netifd: Interface 'wgclient' is setting up now
Sat Oct 18 22:06:27 2025 kern.info kernel: [11941.698635] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
Sat Oct 18 22:06:33 2025 kern.info kernel: [11947.458439] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
Sat Oct 18 22:06:38 2025 kern.info kernel: [11952.578664] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
I will See this Logs in the System
Sat Oct 18 22:06:44 2025 kern.info kernel: [11958.338460] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
Sat Oct 18 22:06:50 2025 kern.info kernel: [11964.098259] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
Sat Oct 18 22:06:55 2025 kern.info kernel: [11969.218261] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
Sat Oct 18 22:07:01 2025 kern.info kernel: [11974.978159] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
Sat Oct 18 22:07:06 2025 kern.info kernel: [11980.018172] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
Sat Oct 18 22:07:11 2025 kern.info kernel: [11985.218027] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=REKEY-TIMEOUT
I tried to start all over again with a reset. Or with cable or with wifi. But no chance.
The Router B won´t connect. Or maybe also something is wrong with Router A?
Would be awesome to get some help!
I assume your provider in Germany uses DS-Lite (like cheap VDSL providers or Cable internet) - in that case you might not be able to open ports. Check How to troubleshoot WireGuard
I got a FRITZ!Box 6660 Cable, which also got WireGuard implemented :confused: . Maybe I only need one Gl-inet Router. But I dont know which Setup I could use.
My German provider got an DS-Lite yes! I See that I can open ports, but maybe not the port from Wireguard.
I saw I need something like Tailscale, but this is not supported for Opal routes :confused: .
I did it. I only need one GL iNet router. My FritzBox can do the rest.
I set up a connection on my FritzBox and now use Router B as a client. My FritzBox is the server.
All you have to do is activate IP6 on Router B. Then it finally worked.
