Opal /w adguard SUDDENLY blocked all traffic
hi,
i knew adguard is not officially supported on opal,
but i did install it and used it for a long time without problem;
btw, opal work as 2nd router, under a brume W.
however, today adguard blocked all traffic instead.
i have to remove it, and switch to rely on adblock to block some websites that i want to block.
problem solved, just post this as a record.
thanks
It could be caused by limited resources of Opal.
You can try removing adguard log or reboot the device.
i got 2 opal, use together under a brumew.
the opals recently unstable.
i now turn back to use a single brumew.
may trouble shoot later.
each time the network sucks, i used several hours to tackle the problem.
i cant do that frequently, so back to simple 1st.
thanks
