yo2ldk
where exactly I can add /setup ports to open and access from network,
for example to DVR - let’s say port 10000 ?
then, @alzao, for future firmware,
can you modify UI in that way if we need to put some app in startup , just check or simply tick a box for that?
alzhao
2
For these things you can do it in Luci, just click advanced settings and go there.
For open port, go to network->firewall->port forwards.
For scripts at start up, go to system->Startup, scroll down to the bottom and fill your script in “Local Startup”.
