With 750m device
To create an openvpn server using the gui, where do I créate the user name and password that I will use on the Client side? Config file is simple, but cant figure out the user name and password.
Thanks.
With 750m device
Thanks.
You don’t need a user name and password as it uses a TLS certificate chain.
The certificate is embedded inside of the configuration file that gets generated.
Try WireGuard on firmware v3.x, much faster than openvpn.
docs WireGuard Client - GL.iNet Docs
firmware GL.iNet download center
It doesn’t support auth-user-pass authentication yet. For personal, I think it is enough, or not?
Thanks I will test and reply if needed.
Great, I will test tomorrow.
