Hi. I have an AR750 Creta and tried to install Openconnect VPN (Not OpenVPN)
What should I do? Thanks!
Have you tried installing the OpenConnect packages? If so, what are the problems?
Yes, I wanted to install an OPEN CONNECT method VPN on my router. The first time I loaded the AR750S file by mistake and bricked it but was able to recover it. I would like to somehow install the OPEN CONNECT method, is there a way to do this? I could not find that file.
Go to the plugin page, update repo and search openconnect.
I am on firmware 4.x so the UI is a different.
Thank you. I get this message, how should I handle it? I am just starting to learn this method and don’t understand it. Please help me out.
Errors
Failed to send request: Operation not permitted
Collected errors:
- opkg download: Failed to download https://fw.gl-
inet.com/releases/v19.07.8/packages-3.0/ath79/packages/openconnect 8.10-2 mips_24kc.ipk, wget returned 4.
- opkg download: Check your network settings and connectivity.
- opkg install pkg: Failed to download openconnect. Perhaps you need to run
'opkg update"?
- opkg install cmd: Cannot install package openconnect.
The opkg install command failed with code 255.
can you ssh to the router and use shell commands?
opkg update
opkg install openconnect
I found the video you guys made. I will give it a try!
I tried the Bitvise method from my Windows computer. However, I got a Windows error 10051 and could not connect.
Can you explain? Cannot understand what is it.
I was able to get into ssh with Bitvise using a different device. However, this is the situation all the time.
root@GL-AR750;~# opkg update
Downloading https://fw.gl-inet.com/releases/v19.07.8/packages-3.0/ath79/packages/Packages.gz
** Failed to download the package list from https://fw.g1-inet.com/releases/v19.07.8/packages-3.0/ th79/packages/Packages. gz
Ok. I will try out later.
Sorry for your time and effort, I really don’t understand a lot. I sincerely appreciate your help.
