We have multiple WAN's at our VPN server and need our GL.Inet routers to be able to support OpenVPN failover.
Reading OpenVPN documentation, one OpenVPN profile appears to support as many
remote xxx.xxx.xxx.xxx 1194 udp
lines as you'd like. The first one to respond is used.
I have tried manually editing the configs in the /etc/openvpn directory and I'm finding out that GL.Inet openvpn client will not follow those typical rules/features.
Is there a workaround or should I be trying to do this a different way?
Thanks.
