OpenVPN Client
Hello Team, I am trying to configure OpenVPN Client in a Flint-2 router, I have imported the Profile to the Flint-2 router, but does not connect, I have Included the Logs. I just tested with 1 Laptop the OpenVpn Server config, and everything works fine with the Laptop , but not from the Flint-2
I will appreciate all your help you can give. Thanks
Mon Oct 27 13:43:50 2025 daemon.notice netifd: Interface 'ovpnclient1' is now downMon Oct 27 13:43:50 2025 daemon.notice netifd: Interface 'ovpnclient1' is setting up nowMon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: Note: cipher 'AES-256-CBC' in --data-ciphers is not supported by ovpn-dco,disabling data channel offload.Mon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: OpenVPN 2.6.14 aarch64-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] [DCO]Mon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: library versions: OpenSSL 3.0.16 11 Feb 2025, LZO 2.10Mon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: DCO version: N/AMon Oct 27 13:43:52 2025 daemon.warn ovpnclient1[31870]: NOTE: the current --script-security setting may allow this configuration tocall user-defined scriptsMon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: TCP/UDP: Preserving recently used remote address: [AF_INET]66.115.177.198:443Mon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: Socket Buffers: R=[131072->131072] S=[16384->16384]Mon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: Attempting to establish TCP connection with [AF_INET]66.115.177.198:443Mon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: TCP connection established with [AF_INET]66.115.177.198:443Mon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: TCPv4_CLIENT link local: (not bound)Mon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: TCPv4_CLIENT link remote: [AF_INET]66.115.177.198:443Mon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: TLS: Initial packet from [AF_INET]66.115.177.198:443, sid=4367f6d9 dfbc0a8fMon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: net_route_v4_best_gw query: dst 0.0.0.0Mon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: net_route_v4_best_gw result: via 192.168.1.254 dev eth1Mon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: VERIFY OK: depth=1, CN=CloudVPN Prod CAMon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: NOTE: --mute triggered...Mon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: 6 variation(s) on previous 5 message(s) suppressed by --muteMon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: [us-dfw-dc1-g1.cloud.openvpn.net] Peer Connection Initiated with [AF_INET]66.115.177.198:443Mon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: TLS: move_session: dest=TM_ACTIVE src=TM_INITIAL reinit_src=1Mon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: NOTE: --mute triggered...Mon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: 1 variation(s) on previous 5 message(s) suppressed by --muteMon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: AUTH: Received control message: AUTH_FAILED,SUCCESS: Authentication successtandard input
sful
Mon Oct 27 13:43:52 2025 daemon.notice ovpnclient1[31870]: SIGTERM[soft,auth-failure] received, process exiting
Mon Oct 27 13:43:57 2025 daemon.notice netifd: Interface 'ovpnclient1' is now down
Mon Oct 27 13:43:57 2025 daemon.notice netifd: Interface 'ovpnclient1' is setting up now
It seems that the authentication failed, but I can't figure out the reason.
  1. Please export the issue syslog.
  2. Please share your openvpn profile with me, you can mark the privacy info.
Please send them in PM.
Thanks I change to proton vpn and now is working but have question is there any way to bypass some apps outside of vpn?
@ja16779 What VPN provider was giving you the failed login? Was it NordVPN by any chance?
Some VPN providers have an account username / password and seperate credentials for the VPN configs
Was openvpn
That's a protocol, I assumed you were using a 3rd party OpenVPN config? hence you said you changed to proton….
Yes openvpn did not work was to complicated to configure access server in the cloud and for that reason change to proton von but I noted can’t use split tunnel
Please upgrade the Flint 2 to the latest firmware first, like v4.8.3.
Switch the VPN mode to policy, and configure the split rules what you want.
Thanks but i use opt 24
Sure, the op24 also has firmware that supports multiple VPN instances, v4.8.2-op24
Hello Bruce, I have configured in the Flint-2 a wireguard server, and in my iphone have the wireguard client. I am able to connect to VPN and connect to the local machines, but I am not able to go to internet from the home where is my wireguard server. I have checked all the config and seems everything looks fine
May I confirm if sure the phone is connected to your home?
For example, can you access the Web UI of your home router on phone? Is the phone able
to ping the IP of the WG interface of the VPN server?
I'd like to know what your VPN client profile, please mark the keys and post here.
Yes, I am able to Login using Weg Gui , I do not know how to ping from the Iphone. I have disable right know.
Updated, I am able to ping to remote wgserver interface 10.0.0.1
is wear, as I am able to do a ping and traceroute from the IPHONE reaching the Tunnel, but I am not able to Navegate
It is working now, as I have a multiwan configured, I just force the network from the Tunnel to go over 1 Link and if this fail choice the second
