Openvpn config reverts on restart
Any way to modify the openvpn server config via ssh without having it overwrite everytime the openvpn server restarts ? client and server ovpn ? This is annoying
What server config options do you want to change, it needs different command.
I only want to route the remote network traffic and not all the traffic over the vpn so removing the default route and adding the remote network route
Sorry I didn’t fully understand. Can you give a screenshot, of what configuration has been changed?
I want to remove push “redirect-gateway def1” from server.ovpn and add push “def1 bypass-dhcp”
Config file /etc/openvpn/ovpn/server.ovpn is not used. Instead /tmp/ovpnserver/ovpnserver is the one that takes effect. For your specific setting, you can use command to substitute default push option:
sed -i 's/push "redirect-gateway def1"/push "redirect-gateway def1 bypass-dhcp"/' /lib/netifd/proto/ovpnserver.sh
We’re developing to optimize this and add more options for OpenVPN server.
