Love this little router!
I’m trying to make it link to my pfsense router remotely through openvpn.
I created an openvpn account for it, the wizard makes a zip with an ovpn file but then the router says it can’t read the p12 cert file also in the zip.
Is there another way I should load the p12?
Thanks all!
Can you post the content of ovpn?
Can you create profile without p12?
Figured out which opvn file format it wants.
If i use my current ip, it works.
If use my no-ip url, it cant resolve.
What am i missing?
Thanks for the time and help!
Never mind, turned out to be a bad resolver.
I’m all set, great routef!
Thanks for the latest firmware!
