my adsl router does not allow to do this. Is it possible to do it from GL-Inet?
Your adsl router doesnāt have the correct routing rules, so the data wonāt go to gl-router at all, thereās no other way for now
would the installation of a gateway be a solution?
With gateways, you also need to configure static routing rules
what is your device model and firmware version?
go to dl.gl-inet.com and find a beta firmware for your device.
this is mine GL.iNet GL-MT300N-V2
ok Iāve upgraded but itās the same as above
You didnāt find the cloud management?
I have updated the corresponding firmware with cloud management.
See this link for how to set up s2s.
