Openvpn will not start after FW upgrade
After upgrade to 2.264 openvpn will not start.
In the GUI it just says “not started”.
I looked in the openvpn config file, but don’t know if there is anything wrong.
Tried reinstalling Openvpn, didn’t help.
Any thoughts?
Where did you try and start it from?
How did you try and re-install it?
I tried in the advanced options of the GUI and also sshd and tried /etc/init.d/openvpn restart.
In the advanced options in the software tab i removed the package and installed it again.
Tried factory reset, still nothing.
