Openwrt 23.0.5 on Mudi
should update openwrt to most current version on mudi? current one on the router is 22.0.3.
If so, how to update. also need the most secured settings on luci if great gurus can advise. Thanks so much!
You can't manually upgrade to new OpenWrt versions.
Please stick with the provided GL firmwares. You can find them here: https://dl.gl-inet.com
