Has anyone tried successfully the new beta 6 or even 5 24.10 on Brume 2?
Thanks!
Thanks!
rc7 yes
Perfect thanks will give it a go later!
Hecatae I thought your Brume 2 was totally busted?
On stock firmware yes
Were you unlucky or are there issues as far as you are aware going to 24.10 and back to stock? Thanks!
@hecatae Do you mean that your Brume 2 doesn't work with GL-iNet firmware anymore but it does work with the OpenWrt 24.10 releases?
Gladly, pretty sure that’s what was meant.
That seems quite strange since GL-iNet says the problems Brume 2s are having look like hardware issues to them. But it's good if OpenWrt firmware can give those dead Brume 2s more life.
