OpenWrt update by Gl.iNet
Hello
@yuxin.zou maybe? You are dev, right?
Will OpenWrt version on which your firmware based be updated to 23.x for following models:
  • E750v2
  • X750v2
  • SFT1200
There are no definite upgrade plans for the E750 and X750 at this time. We will try 23.x or 24.x on the newer models first before the older products.
The biggest problem with these two models is that the hardware is too weak, so upgrading could cause quite a few problems. We still need a technical evaluation. If there are no technical problems, they will be upgraded.
We can't do anything about the SFT1200. It is not Native OpenWrt. it needs to be upgraded by the chip vendor.
