It looks like images are no longer being built for this.
Is it OK to run the stable 21.02.1 from openwrt.org?
Thanks
Thanks
If you mean the v1 version, it has been discontinued for years. It is well supported by openwrt so you are safe to install that.
Yes, I have the v1 and the v2 and was trying to update the older one.
Thanks
