Outdated CA Certificates in Firmware, Official Solution Needed
Hello GL.iNet Support Team,
Following the recent eMudhra CA Compromise: 8 Certificate Keys Exposed, I’m concerned about the outdated CA certificates in GL.iNet’s firmware.
My device is running the outdated ca-bundle (20211016-1). The CA certificate packages have not received updates through the configured repositories.
What is GL.iNet’s official solution for keeping CA certificates up to date on these customized firmware builds? Is a firmware update planned,
or is there a supported way to safely update the certificate bundle and/or related SSL/TLS software packages without breaking compatibility?
Please provide official guidance on how users should address this issue.
Hi GL.iNet Team,
I would like to bring a recently disclosed PKI security issue to your attention and ask whether GL.iNet plans to address it in the current Beryl 7 firmware and the upcoming OpenWrt 25 (OP25) release.
Following the recent eMudhra intermediate CA private key compromise, I conducted a security audit of my Beryl 7 (GL-MT3600BE).
1. Device information
  • Device: GL-MT3600BE (Beryl 7)
  • OpenWrt base: 21.02-SNAPSHOT
  • ca-bundle: 20211016-1
  • ca-certificates: 20211016-1
  • OpenSSL: 1.1.1v
  • curl: 7.83.1
The installed CA packages appear to be based on a certificate bundle dating back to October 2021.
2. Findings
Inspection of the system CA bundle confirmed that the following root certificates were still trusted:
  • emSign_ECC_Root_CA_-_G3.crt
  • Comodo_AAA_Services_root.crt
Both certificates were present in /etc/ssl/certs/ca-certificates.crt, with corresponding individual certificate files and OpenSSL hash links.
These trust anchors are relevant to certificate validation paths implicated in the recently disclosed eMudhra security incident.
I also performed HTTPS tests using the publicly available eMudhra test endpoints:
  • dv-g3b-emudhra.we-have-a-problem.com
  • dv-g3b-aaa-emudhra.we-have-a-problem.com
Initially, normal DNS resolution returned 0.0.0.0, causing connections to encounter the router's local GL.iNet HTTPS certificate rather than the intended test server.
After bypassing DNS resolution with curl's --resolve option, one test connection successfully returned HTTP 200 without disabling certificate verification.
This raised concerns about whether the router's existing CA trust configuration could still accept certificates associated with the compromised intermediates.
However, subsequent attempts to repeat the external test timed out, so I cannot claim a complete dynamic verification of every affected certificate path.
3. Temporary mitigation
As a precaution, I manually removed the two affected root certificates from:
  • The combined system CA bundle
  • The individual certificate directory
  • The corresponding OpenSSL hash links
I retained backups of the original files.
After this modification, static inspection confirmed that both root certificates were absent from the modified trust store.
Normal HTTPS verification continued to work:
  • https://www.cloudflare.com — HTTP 200, TLS verification successful
  • https://deb.debian.org — HTTP 200, TLS verification successful
The router's Xray configuration, DNS services, firewall rules, and other networking components were left unchanged.
This is a local mitigation rather than a substitute for a vendor-supported security update.
4. Questions for the GL.iNet engineering team
I would appreciate clarification on the following:
1. Current firmware security updates
Will GL.iNet issue an updated CA trust store or security patch for Beryl 7 devices still running the current OpenWrt 21.02-based firmware?
2. Upcoming OP25 firmware
Will the planned OpenWrt 25-based firmware include an updated CA bundle and appropriate distrust or revocation measures for the affected eMudhra intermediate CAs?
3. Certificate trust management
Does GL.iNet have a mechanism for distributing urgent CA distrust updates independently of major firmware releases?
Given the importance of TLS certificate validation for router management, firmware updates, package downloads, and other HTTPS-dependent services, this seems particularly relevant.
I understand that removing an entire root CA can have compatibility implications, especially for the widely used Comodo AAA root. A targeted, vendor-supported mitigation would therefore be preferable.
5. Closing remarks
I appreciate the GL.iNet team's continued work on the Beryl 7 and the upcoming OP25 firmware.
My purpose in reporting this issue is to help ensure that existing devices remain secure while the next-generation firmware is being developed.
I have not observed evidence of an actual attack against my router. This report concerns potentially unsafe certificate trust paths and the need for timely security maintenance.
Thank you for looking into this. I would welcome any confirmation from the engineering team regarding the current firmware and the OP25 roadmap.
Thank you for bringing this to our attention.
We have asked our R&D team to investigate the issue and evaluate an appropriate solution. We will share any confirmed updates in this topic when available.
I don't work for gl.inet but I was concern do a backup first and then just remove those certs and rebuild the ca-certificates.crt
also test https from the router (curl / wget) to validate and this command:
openssl crl2pkcs7 -nocrl
-certfile /etc/ssl/cert.pem |
openssl pkcs7 -print_certs -noout |
grep -E 'emSign ECC Root CA - C3|emSign Root CA - C1|emSign Root CA - G1'
Hi!
Thank you for your reply!
Is there any update on this?
Thank you for following up. We have updated the relevant certificate packages for all upcoming firmware releases to address this issue.
For firmware versions that have already been released, we plan to update the certificate-related packages in the package repositories so that users can install the updates directly through opkg or apk. This work is currently in progress, and we will update this topic when the packages are available.
For the Slate Plus that has not seen an update since 2025-04-08, what are we to do? The certificates are not the only security issues currently open on this device. Is this router supported or not?
Based on the message, I assume they will issue a new ca-certificates package and let us know as they said.
Based on all the broken promises on firmware updates to this devices, I have good reasons to have my doubts. I'm waiting on GL iNet to respond.
I saw that both ca-bundle and ca-certificates had updates available in Plug-ins from the admin console on my Brume 2 mt-2500 running firmware 4.7.4. The updated version for both plugins is 20260816-2.
Oddly, after applying the updates, I cannot access the router admin console via local IP in Samsung Browser for Android, but it is reachable in other browsers. DDNS does allow me to use the Samsung Browser. I am putting the output of the installation below which includes the cert/file changes.
Output from update of ca-certificates
Installation succeeded
Upgrading ca-certificates on root from 20210119-1 to 20260816-2... Downloading https://fw.gl-inet.com/releases/v21.02.3/packages-4.0/aarch64_cortex-a53/packages/ca-certificates_20260816-2_all.ipk Removing obsolete file /etc/ssl/certs/TeliaSonera_Root_CA_v1.crt. Removing obsolete file /etc/ssl/certs/18856ac4.0. Removing obsolete file /etc/ssl/certs/SecureTrust_CA.crt. Removing obsolete file /etc/ssl/certs/DST_Root_CA_X3.crt. Removing obsolete file /etc/ssl/certs/d853d49e.0. Removing obsolete file /etc/ssl/certs/3e45d192.0. Removing obsolete file /etc/ssl/certs/244b5494.0. Removing obsolete file /etc/ssl/certs/7aaf71c0.0. Removing obsolete file /etc/ssl/certs/5ad8a5d6.0. Removing obsolete file /etc/ssl/certs/653b494a.0. Removing obsolete file /etc/ssl/certs/4a6481c9.0. Removing obsolete file /etc/ssl/certs/Staat_der_Nederlanden_EV_Root_CA.crt. Removing obsolete file /etc/ssl/certs/ca6e4ad9.0. Removing obsolete file /etc/ssl/certs/QuoVadis_Root_CA_2.crt. Removing obsolete file /etc/ssl/certs/AffirmTrust_Commercial.crt. Removing obsolete file /etc/ssl/certs/9b5697b0.0. Removing obsolete file /etc/ssl/certs/emSign_ECC_Root_CA_-G3.crt. Removing obsolete file /etc/ssl/certs/d7e8dc79.0. Removing obsolete file /etc/ssl/certs/GlobalSign_Root_CA-R2.crt. Removing obsolete file /etc/ssl/certs/AffirmTrust_Premium_ECC.crt. Removing obsolete file /etc/ssl/certs/QuoVadis_Root_CA_3.crt. Removing obsolete file /etc/ssl/certs/4f316efb.0. Removing obsolete file /etc/ssl/certs/Cybertrust_Global_Root.crt. Removing obsolete file /etc/ssl/certs/Entrust.net_Premium_2048_Secure_Server_CA.crt. Removing obsolete file /etc/ssl/certs/Baltimore_CyberTrust_Root.crt. Removing obsolete file /etc/ssl/certs/f081611a.0. Removing obsolete file /etc/ssl/certs/b727005e.0. Removing obsolete file /etc/ssl/certs/5273a94c.0. Removing obsolete file /etc/ssl/certs/40547a79.0. Removing obsolete file /etc/ssl/certs/XRamp_Global_CA_Root.crt. Removing obsolete file /etc/ssl/certs/TrustCor_ECA-1.crt. Removing obsolete file /etc/ssl/certs/SwissSign_Gold_CA-G2.crt. Removing obsolete file /etc/ssl/certs/Go_Daddy_Class_2_CA.crt. Removing obsolete file /etc/ssl/certs/116bf586.0. Removing obsolete file /etc/ssl/certs/VeriSign_Universal_Root_Certification_Authority.crt. Removing obsolete file /etc/ssl/certs/Trustwave_Global_ECC_P384_Certification_Authority.crt. Removing obsolete file /etc/ssl/certs/Certigna.crt. Removing obsolete file /etc/ssl/certs/f387163d.0. Removing obsolete file /etc/ssl/certs/5a4d6896.0. Removing obsolete file /etc/ssl/certs/AffirmTrust_Networking.crt. Removing obsolete file /etc/ssl/certs/106f3e4d.0. Removing obsolete file /etc/ssl/certs/4304c5e5.0. Removing obsolete file /etc/ssl/certs/2e5ac55d.0. Removing obsolete file /etc/ssl/certs/DigiCert_High_Assurance_EV_Root_CA.crt. Removing obsolete file /etc/ssl/certs/aee5f10d.0. Removing obsolete file /etc/ssl/certs/3513523f.0. Removing obsolete file /etc/ssl/certs/f3377b1b.0. Removing obsolete file /etc/ssl/certs/DigiCert_Global_Root_CA.crt. Removing obsolete file /etc/ssl/certs/Trustwave_Global_ECC_P256_Certification_Authority.crt. Removing obsolete file /etc/ssl/certs/76faf6c0.0. Removing obsolete file /etc/ssl/certs/6b99d060.0. Removing obsolete file /etc/ssl/certs/e36a6752.0. Removing obsolete file /etc/ssl/certs/Global_Chambersign_Root-2008.crt. Removing obsolete file /etc/ssl/certs/GeoTrust_Primary_Certification_Authority-G2.crt. Removing obsolete file /etc/ssl/certs/03179a64.0. Removing obsolete file /etc/ssl/certs/b66938e9.0. Removing obsolete file /etc/ssl/certs/9c2e7d30.0. Removing obsolete file /etc/ssl/certs/Secure_Global_CA.crt. Removing obsolete file /etc/ssl/certs/SwissSign_Silver_CA-G2.crt. Removing obsolete file /etc/ssl/certs/Hongkong_Post_Root_CA_1.crt. Removing obsolete file /etc/ssl/certs/349f2832.0. Removing obsolete file /etc/ssl/certs/ee64a828.0. Removing obsolete file /etc/ssl/certs/Staat_der_Nederlanden_Root_CA-G3.crt. Removing obsolete file /etc/ssl/certs/Entrust_Root_Certification_Authority.crt. Removing obsolete file /etc/ssl/certs/Atos_TrustedRoot_2011.crt. Removing obsolete file /etc/ssl/certs/8d86cdd1.0. Removing obsolete file /etc/ssl/certs/3e44d2f7.0. Removing obsolete file /etc/ssl/certs/GTS_Root_R2.crt. Removing obsolete file /etc/ssl/certs/Network_Solutions_Certificate_Authority.crt. Removing obsolete file /etc/ssl/certs/0c4c9b6c.0. Removing obsolete file /etc/ssl/certs/Entrust_Root_Certification_Authority-G2.crt. Removing obsolete file /etc/ssl/certs/Starfield_Class_2_CA.crt. Removing obsolete file /etc/ssl/certs/5cd81ad7.0. Removing obsolete file /etc/ssl/certs/GlobalSign_Root_CA.crt. Removing obsolete file /etc/ssl/certs/Trustwave_Global_Certification_Authority.crt. Removing obsolete file /etc/ssl/certs/080911ac.0. Removing obsolete file /etc/ssl/certs/2b349938.0. Removing obsolete file /etc/ssl/certs/9c8dfbd4.0. Removing obsolete file /etc/ssl/certs/1636090b.0. Removing obsolete file /etc/ssl/certs/TrustCor_RootCert_CA-1.crt. Removing obsolete file /etc/ssl/certs/57bcb2da.0. Removing obsolete file /etc/ssl/certs/Chambers_of_Commerce_Root-2008.crt. Removing obsolete file /etc/ssl/certs/EC-ACC.crt. Removing obsolete file /etc/ssl/certs/Hellenic_Academic_and_Research_Institutions_RootCA_2011.crt. Removing obsolete file /etc/ssl/certs/QuoVadis_Root_CA.crt. Removing obsolete file /etc/ssl/certs/AffirmTrust_Premium.crt. Removing obsolete file /etc/ssl/certs/E-Tugra_Certification_Authority.crt. Removing obsolete file /etc/ssl/certs/c01cdfa2.0. Removing obsolete file /etc/ssl/certs/COMODO_Certification_Authority.crt. Removing obsolete file /etc/ssl/certs/b1159c4c.0. Removing obsolete file /etc/ssl/certs/f39fc864.0. Removing obsolete file /etc/ssl/certs/certSIGN_ROOT_CA.crt. Removing obsolete file /etc/ssl/certs/Entrust_Root_Certification_Authority-EC1.crt. Removing obsolete file /etc/ssl/certs/d887a5bb.0. Removing obsolete file /etc/ssl/certs/DigiCert_Assured_ID_Root_CA.crt. Removing obsolete file /etc/ssl/certs/TrustCor_RootCert_CA-2.crt. Removing obsolete file /etc/ssl/certs/SecureSign_RootCA11.crt. Removing obsolete file /etc/ssl/certs/706f604c.0. Removing obsolete file /etc/ssl/certs/14bc7599.0. Removing obsolete file /etc/ssl/certs/c47d9980.0. Removing obsolete file /etc/ssl/certs/ePKI_Root_Certification_Authority.crt. Removing obsolete file /etc/ssl/certs/02265526.0. Removing obsolete file /etc/ssl/certs/Comodo_AAA_Services_root.crt. Removing obsolete file /etc/ssl/certs/Entrust_Root_Certification_Authority-_G4.crt. Removing obsolete file /etc/ssl/certs/5e98733a.0. Removing obsolete file /etc/ssl/certs/Security_Communication_Root_CA.crt. Removing obsolete file /etc/ssl/certs/626dceaf.0. Removing obsolete file /etc/ssl/certs/e113c810.0. Removing obsolete file /etc/ssl/certs/f249de83.0. Removing obsolete file /etc/ssl/certs/5d3033c5.0. Removing obsolete file /etc/ssl/certs/Trustis_FPS_Root_CA.crt. Removing obsolete file /etc/ssl/certs/93bc0acc.0. Removing obsolete file /etc/ssl/certs/76cb8f92.0. Removing obsolete file /etc/ssl/certs/Sonera_Class_2_Root_CA.crt. Configuring ca-certificates. Updating database. Database update completed.
